TR2/3/3A Oil leaks at two front cylinder head studs?
karls59tr
Bronze
on a club members newly rebuilt motor with hardly any running time on the motor. Is this just a torque issue or could there be something else going on there?
CJD
Karl, I am not seeing how that is possible. Can you give us some more info...is it the very 2 front studs, or the 2 on the intake side?...is it possibly coolant?
K
karls59tr
Bronze
I did not actually see the leaks but was just told about them by the owner. I will try and get more detailed info from him.
R TR2/3/3A Oil Leaks Triumph 24
Nelson Oil leaks again Spridgets 1
D Oil leaks Spridgets 22
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
M PCV and oil leaks Austin Healey 53
T external sealant for oil leaks Spridgets 6
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
M Can synthetic oil be cause of leaks? Spridgets 5
T Oil leaks under carb are - tappet inspection plate Spridgets 6
T sealing oil leaks in a horizontal joint Spridgets 6
rlich8 Introduction/Oil Leaks Triumph 14
K Oil Leaks! Triumph 10
RJS Crankcase Pressurization and Oil Leaks Triumph 11
T OIl Pan, no leaks Triumph 18
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
T oil leaks Triumph 32
M Oil leaks continued Austin Healey 16
M Oil Leaks Again Austin Healey 7
M Oil Leaks Austin Healey 17
E T-Series Oil pipe leaks on '50 TD-help! MG 7
M Common engine oil leaks Austin Healey 16
chrisc Wedge TR8 Oil Leaks Triumph 2
Atrus Let's talk oil leaks ;-] Spridgets 16
G 1967 Midget rear end leaks oil Spridgets 12
Woodie starter works,, but now oil LEAKS !! Spridgets 13
S British cars and oil leaks explained!!! MG 2
G Carb oil leaks out MG 8
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
