Spin-On Oil Filters
twas_brillig
Our BJ7 has an ancient spin-on oil filter adaptor (from AH Spares) that attaches directly to the original canister housing, vs. the adaptors that go to the block.
I did an oil change the other day and discovered I didn't have an extra filter.
My old notes said to use a WIX 5137. However, I found an empty filter box from AH for a Motaquip VFL101 (equivalent WIX is 7098) and the filter on the engine was a WIX 47315.
I sent an e-mail to AH and they advised using a Borg & Beck BFO4077, which equates to WIX WL7098 (using > Oil filter cross reference < ).
Figure I’ll standardize on the WIX WL7098 (or equivalent).
Some comments from an early post, entitled “100 spin on oil filter part number, no oil pressure after replacement”:
Not all replacements have the anti-drain back valve. To check for this valve look at the filter's small holes. You should see a black baffle behind these holes to prevent the oil from draining out of filter when engine is not running.
The Wix filter I use on both my Healeys is their number 51516 (equivalent to the Fram PH3600 I bought with the first one from Moss). Awhile back I bought a dozen on eBay for about $5/per; they're still available from several suppliers.
Purolator 30001 is what I use with a DW screw on adaptor on my 100.
T
twas_brillig
WIX was good enough to advise (for the WL7098 filter) that:
By-pass Valve: No
Anti-Drain Valve: No
Anti-siphon Valve: No
Information from
Mann+Hummel Product Information
Product Information (800) 949-6698)
Mon-Fri, 8:00am-7:30pm, & Sat, 9:00am-5:30pm (Eastern)
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 19
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
J Spin On Oil Filters Triumph 5
scoutll A Series Spin On Oil filters?? Spridgets 8
davidb AH 3000 spin on oil filters Austin Healey 13
K Spin on oil filters.....internal release valve? Triumph 5
W spin-on oil filters Austin Healey 1
jlaird Spin on oil filters Spridgets 13
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
DNK Oil Pump spin up Question Triumph 18
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
P GT6 gt6 spin on oil conversion question Triumph 4
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
