Spin-On Oil Filters Anti-Drain Back Valves
twas_brillig
My brother Ric (a retired, legitimate, auto mechanic) pulled together the following information for me on oil filters from our friend Google (and if anyone is using a spin-on with these various features - please advise):
1): The anti-drain back valve prevents oil from draining out of the filter when the engine is turned off.
During an oil change, it’s recommended you put fresh oil in the new filter before installing it. This is so oil is available to the engine as soon as it’s started.
The anti-drain back valve serves a purpose that’s similar to this oil change strategy. Every time your engine is shut off, the valve keeps oil from draining out of the filter. This allows the engine to receive oil immediately upon start up.
A faulty anti-drain back valve lets oil drain back into the engine. This keeps oil from getting to the engine when it’s first started. The result is engine wear and eventual failure from lack of lubrication. Low-quality oil filters often have a poorly designed anti-drain back valve that doesn’t work properly.
2): three types of valves that can be found in spin on filters:
Anti-drain back valve:
This valve is most often in the form of a rubber membrane adhering to the inner side of the spin-on filter cover. This membrane obscures the holes through which dirty oil gets into the filter. The purpose of the anti-drain back valve is to prevent the oil from escaping from the filter when the engine is switched off. The anti-drain back valve is required in filters screwed from the side or top of the engine body (if the filter’s cover is facing upward, gravity assumes the function of the valve).
Bypass valve
The bypass valve is used when the filter is clogged due to a long period of time between replacements or when the vehicle is running at a low temperature (when the oil is cold and dense). The bypass valve is opened as a result of the pressure increase in order to increase the throughput of oil flow in the engine as there may be a risk of insufficient lubrication of the parts working together. The use of a bypass valve results from the fact that dirty oil is always better for the engine than its total absence. A lack of oil lubrication can damage the engine.
Anti-syphon valve:
This valve prevents the oil from running out of the filter when the engine is switched off. It has a function similar to that of the anti-drain back valve - with the difference that the valve is placed on the "clean side" of the filter. As a result, the filter is constantly filled with oil, regardless of whether the engine is running or not. After starting the engine, the anti-syphon valve significantly reduces dry friction between the parts working together, as it contributes to the rapid flow of oil to the engine.
T Spin-On Oil Filters Austin Healey 1
T Spin-On Oil Filters Austin Healey 19
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
J Spin On Oil Filters Triumph 5
scoutll A Series Spin On Oil filters?? Spridgets 8
davidb AH 3000 spin on oil filters Austin Healey 13
K Spin on oil filters.....internal release valve? Triumph 5
W spin-on oil filters Austin Healey 1
jlaird Spin on oil filters Spridgets 13
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
DNK Oil Pump spin up Question Triumph 18
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
P GT6 gt6 spin on oil conversion question Triumph 4
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
