Spin-On Oil Filters for Cars with a Brake Servo
T
Tricky
I have a BJ8 with Brake Servo. There have been previous posts on the spin-on oil filter topic but the suggestions are usually for cars without brake servos which can accommodate much longer filters. There is about a maximum length of 85mm for cars with servos to allow enough space to fit the filter. I'm after suggestions for a large diameter filter with non-return valve and bi-pass valve that is just less than 85mm in length to maximise filtration and flow. Any suggestions? What are other owners using?
Cheers, Richard
I have the disk-type adapters on both my BN2 and BJ8. When I bought the BJ8's adapter many years ago, the recommended filter was a Fram PH3600. Fram filters, well, let's just say they don't have the greatest rep. I've found Wix filters to be good filters and reasonably priced--you can get a case on eBay for around $65--and they will just fit between the BJ8's block and (stock) servo. The Wix# is 51516, and there is an 'XP' if you want to spend more money.
WHT
Richard,
Not sure where your information comes from, but I use either the Mobil 1 209 or the K&N HP-2009 spin-on oil filters on our 1967 BJ8 with an original Girling brake servo.
They are 4.75-inches (121 mm) and 5-inches (with end nut) (127mm) respectively and both can be installed and removed easily. A little tight, but not a problem.
Regards, Bill
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
T Spin-On Oil Filters Austin Healey 19
AUSMHLY Spin-oil filter, which filters? Austin Healey 25
J Spin On Oil Filters Triumph 5
scoutll A Series Spin On Oil filters?? Spridgets 8
davidb AH 3000 spin on oil filters Austin Healey 13
K Spin on oil filters.....internal release valve? Triumph 5
W spin-on oil filters Austin Healey 1
jlaird Spin on oil filters Spridgets 13
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
DNK Oil Pump spin up Question Triumph 18
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
P GT6 gt6 spin on oil conversion question Triumph 4
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
