TR4/4A Gear oil and choke question
scottkilpatrick
Hi I am new here and have just taken ownership of my dream car a 1962 TR4.
There are numerous things I plan on addressing over the first year - I a fairly novice mechanic but plan on learning a bit over time.
A few questions I have for other TR4 owners. I am not seeing in the manual the current type of transmission oil to use - I plan on changing the the fluids as I have no idea when they were last done. I already did the old and filter.
Question #1 - Can anyone recommend what to use for the transmission fluid?
Question #2 - The choke control is very stiff and does not stay out will pulled - I have to hold it out or it goes back in (off) - can someone confirm if this is standard or should it stay out when I pull it out?
Thanks all
poolboy
See if twisting the choke knob will lock it into position.
Sarastro
The choke knob should be twisted in one direction (CCW, I think) to set it and the other way to release it. But the catch that supposedly holds it in position is not strong and wears easily. As for the stiffness, try a little oil dripped into the end of the cable. If that doesn't work, you may have to take it apart to see what is binding. It is often a little stiff.
Most here will recommend a GL4-rated gear oil like Redline MT90, 75W-90 grade. It's not cheap, but you don't need much. There are others that work, too. The conventional wisdom is that more modern, GL5 rated oils are not compatible with the brass sychro rings, but many GL5 oils these days have buffers that prevent synchro damage. Swepco 901 is one I'm aware of--very high quality, but also expensive (~$100/gal). However, it may be hard to determine which ones are OK. I just use the MT90 in the TR4A and be done with it.
Good luck with your "new" TR4! Keep us informed as to how you're doing with it.
scottkilpatrick
scottkilpatrick
Thanks everyone. I figured out the choke was a twist - thanks for that. I will go with the Redline. Anyone know approx how much it takes - the manual doesn't say.
Sarastro
A non-overdirve transmission will require a little over a quart. With overdrive, I'm not sure, but I suspect two quarts should be enough.
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
mrv8q TR2/3/3A Mixing MT-90 with Hypoid Gear Oil? Triumph 13
tinman58 Off Topic GL4-GL5 gear oil Triumph 6
S TR4/4A Trans/OD gear oil? Triumph 14
Rut GL4 gear oil Spridgets 3
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
T Gear Oil Leak Austin Healey 17
J TR2/3/3A Gear oil in the gear box? Triumph 13
Gerry M TR6 TR6 gear oil Triumph 8
A Proper Gear oil? Triumph 9
J Healey Gear Box & OD oil Racing 5
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
rkep01 Cornhead grease vs hypoid gear oil Spridgets 6
KVH GL4 Gear Oil Triumph 5
rlich8 Gear Oil Triumph 9
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
R SAE 90EP Hypoid gear oil MG 2
A Gear box oil MG 9
ekamm gear box oil Triumph 13
lbc_newbie Gear oil type for 210 4 speed tranny.... Spridgets 3
M Gear oil? Spridgets 4
dklawson Transmission Gear Oil - Synthetic? Triumph 7
W Silly question Gear Box oil change/top up MG 11
R Best gear oil for transmission in midget[snail] Spridgets 3
Shinsen774 Rear Diff Gear Oil Change Interval MG 2
OregonTR4A Adding gear oil to the gearbox? Triumph 8
LuckyLuke Right Oil for BN1 axle and gear box Austin Healey 4
R MG MIdget 1500 gear box oil changing MG 0
R MG MIdget 1500 gear box oil changing Spridgets 13
vping Rear Gear oil MG 1
A TR4/4A TR4 gear box oil Triumph 13
W MGB MGB GEAR BOX OIL. MG 7
tahoe healey gear box/ OD oil Austin Healey 6
G GL-4 vs GL-5 gear oil Restoration & Tools 6
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
