Rear Diff Gear Oil Change Interval
Shinsen774
Seems like the traffic on the site is a little light so I figured I'd ask a few simple questions I have to get y'all's opinions (I am from North Carolina so I can use the double contraction y'all's). I am an LBC novice and certainly no mechanic and appreciate your insight.
I have a '64 MGB, banjo rear diff with about 157,000 miles and was restored twenty or more years ago. I changed the diff gear oil (90w) last January. I am driving about only 1200 to 1500 miles a year. Car runs great. How often should I change the rear diff oil under these conditions (miles and/or months)?
Same question for the transmission oil (3 syncho). I used Castrol 20w50 about a year and 1200 to 1500 miles ago. Tranny shifts smoothly, no problems, oil level remains constant and looks clean on the dipstick.
Thanks for you thoughts.
PAUL161
Not trying to sound strange but, if you changed the oil in the rear last year, you probably won't have to do it again for another 5 years or so. As long as there is no metal particles in the rear, the oil, (90wt), will last for years.
As for the transmission, if it looks clean and everything is working proper, maybe every 30 to 50,000 miles. If the dipstick shows water droplets or foam, say from condensation during storage, then I wouldn't hesitate to change it. That's just my personal opinion. PJ
wangdango '67 XKE rear diff? Jaguar 2
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
A TR4/4A Changing rear diff seals Triumph 15
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P rear diff crownwheel help Triumph 3
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
D Spitfire spitfire diff and rear spring Triumph 9
M Rear diff. bearing ID Spridgets 2
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
H IRS diff rear mounting bracket Triumph 0
J 100 rear diff - nut torque Austin Healey 4
Dudly Rear Diff Oil Triumph 11
N Rear Diff mounts upgraded Triumph 2
VelodromeRacer Rear Diff oil suggestions? Racing 7
D TR4/4A TR4 rear diff pinion seal Triumph 4
W used rear diff Triumph 2
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
