Rear Crankshaft Bearing Cap
BT7 Owner
Hello All,
I have a 1962 MK II that I have installed a rear crank seal kit. The seal seems to have a minor drip when parked.
A while ago I heard about drilling a hole in the rear of the main bearing cap to help drain oil from the lip seal area.
Has anyone had any experience doing this? I have searched but was not able to find any info about this procedure.
Any advice would be appreciated.
BoyRacer
There is no such thing as drilling a hole to drain oil from the rear seal. There is already a space in the rear main cap for oil to drain down into the oil pan.
BT7 Owner
BT7 Owner
Richard, thanks for the reply. Are you talking about the pipe that drains the oil from the rear main? The drilled hole that I heard about was supposed to be rear of the pipe and maybe drain the scroll area? I have my sump off right now and I thought maybe this was something I could do to help with the drip from the rear main seal kit. Oh well, I thought I would ask before I do something stupid!
The seal kit we put in our BN2 recommended drilling the hole; but, my dad didn't like the idea so we didn't do it. It's been theorized that the pipe that drains the rear main cap is too long and, as the end is submerged doesn't allow enough drainage, so some have claimed to have shortened it.
BT7 Owner
BT7 Owner
Thanks Bob for the info. I found a thread on this site that is very interesting that goes along with what you talked about.
> Rear crank seal oil leak BN2 <
They talk about the rear main bearing pipe and removing it for better flow from the bearing and also a drilled hole.
T crankshaft (rear) bearing leak Spridgets 2
vette Crankshaft Rear Oil Seal Austin Healey 11
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
Mio Rivergate Rear Crankshaft Seal Instructions Spridgets 16
Michael Oritt Rear crankshaft seal for 1500 engine? MG 5
P TR2/3/3A TR3A Rear Crankshaft Seal Triumph 2
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
