TR4/4A Rear fender attachment: wing to lamp housing clip?
Popeye
Bronze
Hi all,
I installed one rear fender this weekend on my TR4A. I am using the TRF mounting kit, RFK160 - likely the same as carried by other vendors.
The kit includes four clips: 608522, “Clip, wing to lamp housing”.
Where and how do these clips get installed?
I assume They are installed after the tail lamp is attached to the tub… But it is not clear to me where a clip is needed??
charleyf
Can you provide a picture of the clip? I have researched the clip and can not find any diagram as to its shape or where it goes. But it is listed in the parts manual. Just not shown in any pictures.
Charley
Popeye
Popeye
Bronze
mctriumph
This was not used here at all at any time. The factory used electrical tape around the wing/housing,going all
around to "seal" the wing and I presume sace the paint from chipping when the lamp was "affixed "
Mad dog
Rod-H
Bronze
Hi Mike:
The clips in the picture in your hand appear to be upholstery clips. They look very similar to the ones used to hold the vinyl to the dash pad.
Rod
Sarastro
Yes, I think those are the upholstery clips, also used on the seats of a TR4A. Whatever the original use, you really don't need them for installing the feders or tail lights.
Popeye
Popeye
Bronze
Thanks everyone for the replies; I’ve decided not to use them. Bottom line, I do not see the benefit in using the clips.
I received a reply on the Triumph Register forum that the clips go on the top and bottom of the lights. https://www.tr-register.co.uk/forums/index.php?/topic/82729-rear-fender-installation-clip/
The spare parts catalog lists the clips as two different parts; see images below of the index and the page of center mounting parts.
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
vette MGB Rear Fender Dog Leg Patch Panel MG 3
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
D TR2/3/3A rear fender bead Triumph 2
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
B TR2/3/3A Rear Fender Part Triumph 3
A Fender bead photo rear fender Triumph 12
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
S TR2/3/3A rear fender vinyl tr3 Triumph 6
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
RickB SWA formerly RB Midget needs rear fender flaring Spridgets 60
M 3000 MKII racer Exhaust exit in rear fender Austin Healey 1
J Tracing the opening of a AH 100-4 rear fender Austin Healey 10
Lynn Kirkpatrick MG REAR Fender MG 2
CJD Rear fender screws Triumph 11
Stinger TR4/4A TR4A Rear Fender Bolt Removal Triumph 6
R TR4/4A TR4-A rear fender Triumph 12
luke44 TR2/3/3A TR3 Rear Fender Alignment at Front Edge Triumph 8
mountainman TR2/3/3A TR3 Rear Fender Mounting? Triumph 4
JFeher TR2/3/3A 59TR3A Rear Fender value Triumph 6
D Rear Fender Fasteners Austin Healey 3
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
Marvin Gruber A/H Right rear Aluminum Fender Austin Healey 0
66healey removing rear fender Austin Healey 3
mountainman TR2/3/3A TR3 Rear Fender Bolts Triumph 2
R big healey rear fender trim Austin Healey 5
T Paul [apbos] how did the rear fender removal go? Triumph 5
Tinkerman TR2/3/3A TR3A Rear Fender Stone Guards Triumph 4
T Rear inner fender repair - are you brave enough? Triumph 6
Z 100/4 Rear Fender Potential Rust Area Austin Healey 8
M TR2/3/3A TR3 Rear inner fender dent repair Triumph 8
R Spitfire '75 Spitfire rear fender top trim Triumph 0
mcguijo TR2/3/3A Clamp plate on Rear Fender TR3A Triumph 16
fad64b TR2/3/3A TR3 rear fender stone-guards Triumph 22
Bob Claffie Rear fender install[100/6] Austin Healey 3
T TR6 Today's TR6 rear fender progress Triumph 8
beaulieu TR6 TR-6 rust on the rear fender, upper rear corner- Triumph 1
W Rear fender fillers. Triumph 3
mcguijo TR2/3/3A TR3 rear fender Triumph 15
Lin Rear Wing [fender] fasteners Austin Healey 1
M Rear fender beads Jaguar 10
G TR2/3/3A TR3A rear fender captive bolts Triumph 7
J Need help getting rear fender off Triumph 8
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
