Rear Main Seal Kit
J
JKAHouTX
Hello, John here. Does anyone have an opinion on the two-piece rear main seal conversion kit for a '67 3000 BJ8? I’m putting my newly bored engine back together and thought about ridding the typical oil leak, but am reluctant to drill and tap the block. Thanks.
S TR2/3/3A rear main seal is leaking Triumph 13
D rear main seal Austin Healey 13
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
A Rear Main Oil Seal Conversion - Bearing Cap debris Austin Healey 5
V TR6 TR6 Rear Main Seal Triumph 17
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
S TR2/3/3A tr3 rear main seal Triumph 6
A TR6 TR6, Best front and rear main seal ??? Triumph 0
C rear main oil seal Austin Healey 4
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
Gerard 1098 "10CC" rear main Spridgets 0
S TR2/3/3A tr3 rear main Triumph 24
TraceZ rear main leaks Spridgets 3
B rear main Spridgets 5
B rear main puller Austin Healey 6
