Rear Main Oil Seal Conversion - Bearing Cap debris
Andrew1
Hi:
With so many that have done the Moss conversion kit for the rear main oil seal, I was hoping someone can comment on the metal debris as a result of drilling and tapping.
In my case the main bearing cap and the rear of the engine block were perfectly aligned, not requiring me to remove the oil sump and undo the rear main bearing cap nuts to adjust.
I am happy about that, but in the instructions, there was made mention the the cavities of the rear main bearing cap would have to have metal debris removed as a result of the drilling. I cannot feel any cavities as a result of the drilling to the depth of 10 - 12 mm that I have done.
Am I missing something, or would I be wise to drain and remove the sump for an inspection anyway. Any comments would be appreciated.
- Andrew -
Dave Russell
Yoda - R.I.P
If you are ABSOLUTELY sure that there are NO microscopic chips remaining, where they can get into the internals, It might be OK. I would be nervous about it.
Ed Kaler
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I would be nervous about it. [/QUOTE]
:iagree:
I would be <span style="color: #990000"><span style="font-weight: bold"><span style="font-style: italic"><span style="font-size: 17pt">WORSE</span></span></span> </span> than "nervous", gents!!
I'd be scared silly!!!!! :pukeface:
:cheers:
Ed
steveg
Re: Rear Main Oil Seal Conversion - Bearing Cap de
Am not sure what folks are worried about here. One drills into the block, but not through into the inside. Any chips either fall outside or remain in the screw holes.
As I recall the instructions called for drilling to a certain depth only. That's how I did mine and it wasn't difficult.
The Moss kit I bought had metric screws and I replaced them with stainless 10-32s, as I had a 10-32 tap and didn't believe in putting metric threads at odd places on a Healey.
Dave Russell
Yoda - R.I.P
It's true that you are drilling blind holes that don't go through into the inside. But, do any of the chips fall down on the exposed crankshaft or the rear main bearing joint. ANY grit here will cause major problems.
See if this helps:
www.mossmotors.com/graphics/products/PDF/833-415.pdf
Where Moss suggests replacing the felt plugs with silicone sealer, I've found that silicone sealer will never set when it is injected into a deep closed hole. It requires exposure to moisture in the air to set.
I had much better luck injecting a fast set two part compound called "Duramix" into the felt plug holes. Duramix is used by body shops to repair flexible "rubber" bumpers.
Also be very careful to seal the main cap bottom to the sump flange. If the main cap surface is the slightest bit below the surrounding sump rail surface it will leak. The sump gasket kits often supply a thin cork strip "extra gasket" to fill this space.
I would also use a thin coat of sealer on the -main cap to block- horizontal parting surfaces.
I can tell from experience that this is NOT a job that you want to do twice!
bob hughes
A bit late for Andrew, but I used a foul smelling heavy cutting grease that kept the drill swarf on the bit itself so that there was little or no spillage and the holes were clear. This was checked out when I cleaned the grease from the holes as I used loctite on the screw threads.
Bob
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
C rear main oil seal Austin Healey 4
J Rear Main Seal Kit Austin Healey 1
S TR2/3/3A rear main seal is leaking Triumph 13
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
KVH TR4/4A Viton Rear Main Seal Triumph 12
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
S TR2/3/3A tr3 rear main Triumph 24
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
B Rear main seal kit Spridgets 3
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
P how to replace rear main seal in 1500 midget Spridgets 2
TraceZ rear main leaks Spridgets 3
R Rear main seal question. Spridgets 29
MGTF1250Dave Improved TR Rear Main Seal Kit Triumph 19
KVH TR4/4A Rear Main Seal TR4A Triumph 17
B 1970 XKE 4.2 rear main seal Jaguar 2
B rear main Spridgets 5
B rear main puller Austin Healey 6
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
M TR2/3/3A TR3 crankshaft rear main seal opinions wanted. Triumph 8
58Custom 1275 Rear Main Seal Kit- - seek info Spridgets 2
glemon Rear engine main seal review Triumph 7
J Moss rear main seal. Austin Healey 5
TimK Rear Main Seal Kit Installation Austin Healey 24
M Rear main Scroll Seal Triumph 11
V TR6 TR6 Rear Main Seal Triumph 17
jlaird Installing the rear main cap cover correctly: Spridgets 3
aaronclark TR2/3/3A TR3 Rear Main Seal Questions Triumph 7
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
spartan0199 rear main seal kit 833-145 Austin Healey 12
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
fad64b TR2/3/3A Rear main seal TR3 Triumph 12
