A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal
Wayne's Austin
I have an oil leak to bell housing / clutch area, from rear main bearing. I note that the original design does not use an actual seal, but rather any oil that travels along crankshaft is intended to hit a machined groove in the crankshaft, which is intended to carry it back to an oil well in the rear main bearing cap, where it drains back to the oil sump. Has anyone worked on any improvements on leakage thru this system and/or added an after market seal to help reduce oil loss thru the original design arrangement? I had issue with the clutch pressure plate getting wet, so oil leakage needs to be reduced or hopefully eliminated. Any comments / suggestions?
78Z Project Austin A40 Somerset ā€˜Specialā€™ Other British Cars 10
JPSmit Somerset on bring a Trailer Other British Cars 1
JPSmit Separate Thread - A40 Somerset hood [Bonnet] ornament Other British Cars 0
aeronca65t Austin Somerset - eBay Other British Cars 0
S austin a40 somerset chassis swap/upgrade Restoration & Tools 2
B How many of you have or had an Austin A40 Somerset Other British Cars 16
B Austin A40 Somerset build Other British Cars 31
A Restoring '53 Austin Somerset Other British Cars 9
Grannieannie Somerset dashboard Other British Cars 5
Grannieannie 1954 Austin A40 Somerset Other British Cars 17
S Austin A40 Somerset convertible Chicago CL Other British Cars 0
JM1NA 1952 austin somerset Other British Cars 15
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
T How much dashpot oil leakage is normal Triumph 14
dklawson Spitfire Water Leakage Paths - Spitfire Triumph 16
B Fuel leakage at carby on V12 Jaguar 4
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
