MGB Rear wheelbearing clicking
Carlbanan56
Carlbanan56
Member
I am currently trying to restore the breaks on my MBG from 1975 which has not moved in 25 years. I have just taken apart the rear brake and have ordered new shoes, new spring and more. When I out of curiosity spon the hub I could clearly feel a sort of clicking. I checked the hub on the other side and I could feel the exact same clicking. Is this problematic? Is this just bad bearings?
Every insight is appreciated :smile:
drooartz
I would certainly check the bearings, given how long the car has sat. At the very least clean and repack is easy enough.
Grantura_MKI
these are rear bearings and run in gear lubricant. drain the diff fluid and refill. Bearings usually last for ages as long as fluid is present.
be sure to check after running in for diff seal leaks at the hub.
YakkoWarner
Another possibility is wear in the differential or possibly a stuck/worn universal joint. I've had the rear seals go out but it normally takes some sort of physical impact or shock to damage the bearing itself, unless as Grantua mentioned they were allowed to run dry.
REALLY oddball case would be if someone had installed some sort of positraction or limited slip in there, which could make it feel different....
YakkoWarner
After re-reading; an additional question. Is it a continual clicking (like a clock) as the hub turns, or is there just a single click when the hub is first turned? If it is just a single click, that would point me more toward a worn gear in the diff or again, a worn u-joint that moves a bit before taking up the slack and engaging.
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
