Rear/Differential "Clunk"
twas_brillig
I took a 3000 km/1900 mile run in late May in our BJ7, and developed a 'clunk' in the rear about the time of the return home. I was thinking suspension, but couldn't see anything when crawling around underneath (we're running Udo Putzke's Fahrspass tubular Bilstein shock conversion, and are very happy with it).
Buddy Jeff was over this afternoon and pulled the rear seats, which allowed access to all the shock etc. mounting bolts. Three bolts weren't as tight as he felt they should be, so he snugged them up. We went for a test drive (sans rear seats) and the 'clunk' was gone. So, lesson is that you pull the rear seats so that you can have access to the shocks etc. etc. there, and get to listen to weird noises when driving with them out. Doug
Bob McElwee
The other option is either at the end or begi. Int of the driving season check the rear shock mounting hardware for tightness.
On the rear shocks, even if you torque the snot out of them they can work loose; probably from being in shear with heavy, jarring side loads. I'm hoping the NordLock washers I installed do the trick.
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
J TR6 Differential / Rear Axle Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
D TR2/3/3A rear shelf differential dome Triumph 9
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
KVH General TR Rear Differential Seal Triumph 7
C TR2/3/3A Rear differential Triumph 29
A Rear Differential Concern??? Triumph 11
T Spitfire Spitfire differential rear bushings Triumph 5
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
J Rear Axle/Differential Gear Oil Spridgets 13
zschicago Replace rear differential gasket? Austin Healey 12
R MGB MGB Tube Type rear differential MG 0
R use redline mt-90 in 1275 rear differential? Spridgets 3
N Differential and rear suspension Austin Healey 113
I rear axle to differential flange bolt grade? Triumph 8
N Rear Differential Rebuild Triumph 9
KVH Rear Differential Overflow Valve Triumph 3
Lin Rear Differential bearings Austin Healey 2
C TR2/3/3A Broken TR3 rear differential Triumph 9
G Rear Differential - Pinion Gear? Austin Healey 3
jerrybny Differential/Rear Axle Gaiter question Triumph 6
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
