TR4/4A Removing Rear Differential Seal--Solid Axle
KVH
I have a small puller but the oil seal seems stuck, and I'm afraid the feet of my puller might be slotted behind a cast iron lip inside the differential housing. Anyone have advice on removing that seal, and whether my fear about there being a lip is valid.
TR3driver
Great Pumpkin - R.I.P
Are you talking about the oil seal for the half shafts, or the pinion seal?
IIRC the ledge behind the pinion seal doesn't have a lip on the other side (the bore just gets smaller), but I don't recall what the side seal looks like.
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
busybrit Removing the drain tube fron the rear mains cap. Austin Healey 4
R Removing rear quarter elliptical Spridgets 5
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M Having a hard time removing the rear bumper [pic] Triumph 4
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
66healey removing rear fender Austin Healey 3
TR3MT Removing rear fenders Triumph 10
drooartz Removing the $@#! rear hub oil seals Spridgets 3
Ohiobugeye Whats the key to removing the rear radius arm bush Spridgets 6
Guinn removing rear rubber bumper MG 6
T Help removing the rear drive flange Triumph 2
HAN8L1965 Removing backing plate on rear drum brakes Spridgets 3
sultanoswing T-Series Removing Rear Hatch - tight screws!! MG 1
bluemiata90 Removing rear springs Triumph 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
