General MG Thoughts on removing a stubborn 2-ear spinner
Jrmandella
Car: 1965 MG Midget
Issue: Driver-side front spinner will not budge. I tried a few things and found some interesting solutions
What I have tried
  • I have a clark and clark spinner wrench. It worked perfectly on the other 3 wheels
  • I have tried a soft blow, sand-filled hammer
  • I tried a few whacks with an iron hammer
Comment: I plan to replace the spinner, please no lectures on using the iron hammer.
Questions:
  1. What would be a good way to heat the spinner? Propane or Butane? For how long? I don't have access to acetylene
  2. Any tips on cutting off the spinner? I don't plan to reuse it even if it comes off cleanly. If it won't twsit off in my garage, I'm not trusting on the side of the road
  3. I saw a video on using a 2-prong tool to engage the ears and loosen with an impact/pneumatic wrench -- It is a $300 tool (interesting but I could buy 4 spinners at Moss)
  4. I saw a few videos where someone used a handheld pneumatic hammer. The hammer was held at an angle and the pneumatic action made the spinner move. Thoughts please?
Appreciate your comments. Many thanks in advance
NutmegCT
Just a thought - use the wooden spinner wrench *backwards*. In other words, mounted on the spinner. use a hammer as tho' you're *tightening* the spinner. One blow should break the thread grip enough to allow using the wooden wrench in the normal *loosen* direction.
Tom M.
J
Jrmandella
Thank you . My spinners have "UNDO" arrows on. I am following the direction of the "UNDO arrow". the other 3 spinners can be removed with minimal effort. I tried hitting the long Clark and Clark wrench with hammer, it figured extra force with 2ft of leverage would work. Nothing
I think the hubs are original from the factory, so the possibility of a hub that was made for the opposite side is small
bobhustead
Impact is going to be more effective than leverage. Your description of the suggestion of an air chisel (with a blunt bit) on Utube is interesting, but I don't know if the mass of the tool would be enough. If you could put hands on a heavy brass hammer you might have some success. My suggesting brass is not concerned with the spinner. A less elastic collision than that with the steel hammer you used would provide a more effective transfer of force to the spinner. I am thinking of a hammer weighing about 3 pounds.
Bob
bobhustead
Tom's suggestion was to deliberately whack it in the direction you do not want it to go to induce a tiny break in the corrosion that has it locked up. Not a bad thought. But I would whack it directly without the spinner wrench.
Bob
bobhustead
'Nother thought. Use one you have off to guesstimate where the spinner threads and spindle threads meet in ref to the round face of the spinner. Drill a couple holes there and soak with aerosol penetrant.
Bob
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
C 1960 BT7 Thoughts Austin Healey 14
C TR4/4A TR4 Thoughts Triumph 15
C MGA MGA Thoughts MG 20
AngliaGT Thoughts/advice on Miatas? Other Cars 22
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
D TR2/3/3A Any thoughts on this part? Triumph 6
M Next job[s] on Otto - thoughts? Spridgets 35
G TR4/4A Thoughts on my coolant Triumph 12
Jim_Gruber Thoughts on driving Bugsy with the hardtop installed. Spridgets 32
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
B Thoughts...rough running at cruise. Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
Rut TR6 Thoughts on this car? Triumph 10
D Thoughts on Paint Removal... Austin Healey 11
AngliaGT Thoughts on Volvo wagon? Other Cars 5
cmacmillan TR6 TR6 grille repair - thoughts? Options? Triumph 6
AngliaGT Thoughts on Miatas? Other Cars 11
J Thoughts on waxing new paint? Austin Healey 14
KVH TR2/3/3A Thoughts on This EBay TR3 Please Triumph 25
Brinkerhoff Thoughts on car lifts ? Restoration & Tools 13
N Spitfire New thoughts on a.c. in Spitfire Triumph 11
Mink TR4/4A Your thoughts/value of this TR4 Triumph 357
HealeyRick Nasty Thoughts - Driving Impressions Austin Healey 15
F Thoughts on aftermarket air cleaners? Austin Healey 12
B Wiring Harness Issues -- Any Thoughts? Spridgets 6
KVH Some Thoughts Entering the New Year Triumph 18
Flash_Harry Any thoughts on these spark plugs? MG 9
richberman Thoughts on canted car? Austin Healey 15
lbc_newbie thoughts on exhaust Spridgets 9
T TR2/3/3A Thoughts on a TR3a Triumph 12
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Some random thoughts on a cool, sunny day Triumph 9
John250 TR5/TR250 Thoughts on selling my restored TR250?? Triumph 33
glemon Blasphemy Impure Thoughts Triumph 22
JPSmit Bought a Tool Chest today - thoughts needed. Restoration & Tools 16
bugedd Thoughts on this radiator Spridgets 9
AN5Sprite Tunebug engine diagnosis, thoughts anyone? Spridgets 47
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
Stick Thoughts on Spridgetech Fiberglass Bonnets? Spridgets 2
T TR6 Thoughts on Superchargers for a TR6 Triumph 25
bugedd Bonnet thoughts... Spridgets 3
John_Mc Mechanic error? Thoughts? Other Cars 19
JPSmit Expansion tank thoughts Spridgets 6
DNK Lift THoughts Restoration & Tools 14
DNK Need Thoughts Triumph 57
