Removing the Rear Axle Seal
Jim_Gruber
Guys any tips on removing the rear axle seal. I do not over a seal puller. This hub was doing same major leaking and there is all kinds of baked on crusty 90 W like tar on the inside. I got the bearing out but seal at least tonight is stuck. I placed the hub outside in a container of old gasoline to see if things could soften up overnight. Spring is out as well. But attempts with a thin screwdriver so far do nothing but tear up rubber. Gasolin should help to help me at least see where the seal ends on the inside and the hub begins.
Jim_Gruber
Jim_Gruber
Guys, One Axle Seal Bites the dust. Could not find a seal puller tonight but while perusing tools I ran across this bad boy below. Vice Grip all in one Fence Pliers. Pliers, Hammer, Wire Cutter, and one Nasty Sharp Spike on the end of it. Perfect for digging into the axle seal and prying it up little by little until I was able to get a tiny bit of movement and space. Enough to flip the hub over and get a screw driver under the lip and with the assistance of my 5 lb persuader, one smack and the seal was out of there. I know I will find other uses for this cool tool.
Cleaned all of the rust up on the inside of the Hub with my trusty Dremel, cleaned all of the mating surfaces with Acetone and 000 Steel Wool, wiped everything down, masked all mating surfaces and gave it a shot of Gloss Black. Used Steel Wool on one of my EN17 Axles and smoothed everything out on the axle shaft, a bit rusty from sitting in the back of a too humid garage and it cleaned right up, smooth as butter. A little more Gloss Black on the end of the axle shaft, mating surfaces polished clean with Steel Wool this one will be ready to reassemble shortly. New 207FF Sealed Bearings will be installed along with new Axle Seals and that part of one side is almost finished.
That side was totally nasty with dried and crusty Diff Oil sitting on there like Roofing Tar. This one definitely needed to come apart for some R&R. Brakes on the LR Side were totally soaked after just a few weeks of being out and about in September and October. Glad I got this taken care of. Next up time to pull the other side.
PS a secret tip I think helped. I poured as small amount of Acetone around the axle seal and let it soak in for a few minutes. Acetone dissolves rust and I think that helps to break 57 years of associated crud under that axle seal loose.
nomad
OK Jim, get some wire, post's and staples and fence your yard!
Jim_Gruber
Jim_Gruber
hey that's one really nice tool for that sort of work. Now that I bought a second tool chest I can expand my "Pliers Drawer" . Same with Standard and Phillips Screwdriver Drawers and my Sockets can actually be classified and sorted into 1/4", 3/8', and 1/2" Drives in different drawers Standard/Metric so I can actually find stuff when I need it. Old Tool chest is so overcrowded I can't find things or there is no room to put tools in there. Then I can't find it and I end up rebuying the tool all over again because it's easier to rebuy than hunting and hunting and hunting for that one special wrench you need.
nomad
It's my experience that no matter how much you organize, you can never find what your looking for!!
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
busybrit Removing the drain tube fron the rear mains cap. Austin Healey 4
R Removing rear quarter elliptical Spridgets 5
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M Having a hard time removing the rear bumper [pic] Triumph 4
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
66healey removing rear fender Austin Healey 3
TR3MT Removing rear fenders Triumph 10
drooartz Removing the $@#! rear hub oil seals Spridgets 3
Ohiobugeye Whats the key to removing the rear radius arm bush Spridgets 6
Guinn removing rear rubber bumper MG 6
T Help removing the rear drive flange Triumph 2
HAN8L1965 Removing backing plate on rear drum brakes Spridgets 3
sultanoswing T-Series Removing Rear Hatch - tight screws!! MG 1
bluemiata90 Removing rear springs Triumph 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
