TR2/3/3A Removing a stuck oil drain plug
sp53
Removing a stuck oil drain plug. The plug looks stock, and it is the square one about 7/16. This thing is stuck and has not been all mangled, yet. I tried heat, and have been using a Proto quality 12 inch adjustable. I do not want to go to vise grips or a pipe wrench yet. Is there a socket that fits those things or something? Any ideas?
Steve
KVH
Steve
Like others say, avoid all tools other than a square wrench. Absolutely nothing would work on my drain plug other than a square wrench. I’ll spare you all of the terrible details, but I tried removing a transmission plug without a square wrench, using all kinds of sockets and wrenches, and the result was a nice round “unremovable” plug. Imagine trying to remove a rounded plug. There is no alternative other than a very steady hand with bright lights drilling straight through the middle of the plug and then extracting it with an easy out.
CJD
TR2's came with a brass plug...so the good news is it is not an original. Keep upscaling until you finally have to weld a handle to it and get it out.
AngliaGT
I found a bolt remover at Leow's .It was even made in the US,
and it worked. Ut's made by IRWIN,& comes with 4 different sizes.
charleyf
Do yourself a favor . Once you get it out and replace it with a magnetic plug. It will be a hex head.
Charley
S
sp53
Well I got the plug out by clamping my favorite flat jawed vise grips at the back of the jaws on the bolt very tight. Then what I did was lie on my back and push will my legs and the bolt broke lose. The sad part was as I crack the bolt slowly water came out, I mean 5 quarts of water. The water filled my drain pan almost to the top, so I dumped that and will get the rest out soon.
The engine is now not that big of concern to me. I have another engine I was rebuilding before I bought the car. I plan on rebuilding it this winter.
steve
CJD
I suspected that when you said the engine was over-filled with oil. Did you ever determine if it is the original TR2 block or not?
S
sp53
Yes the engine is a tr3. I think it was TS 50K something and the head is high port. I am not sure what to do with this engine for now. I really do not want to fiddle with it because of the water. The head gasket is probably blown or a crack somewhere. I suppose best case is rain water, but I am usually a dreamer. Plus, I bet that engine comes apart difficulty, like getting the head off. Perhaps I will put some oil in and set the engine off to side. I see no reason to spin the engine with a starter, but it would probably push some oil around. What do you think?
steve
CJD
Good choice. If it isn't original there is no need to waste time on it if you have another donor. My bet would be rain water too.
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
71tr Removing Stuck Overdrive Unit Triumph 3
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing Glass Windshield Triumph 4
