Spitfire Removing Transmission/Gearbox from underneath
Bona42na
Hello All, I am new to British Car Forum and this is my first post. I have a 1978 Spitfire and have seen many articles about removing the transmission from the inside of the car. My question is, Can the transmission/gearbox be taken out from underneath the car. I really don't want to remove the seats/rugs if I don't have to.
Thanks...
Andrew Mace
Short (and long) answer: No. Even if you pull the engine and gearbox as a unit from under the bonnet, you still have to be able to get to the rear mounts, the propeller shaft flange bolts, and the shift lever mechanism to get all that stuff out of the way...which really only can be done by removing carpeting, the "H" brace and the gearbox cover.
dklawson
+1 to what Andy said.
The first time you pull the gearbox it might take more time than you expect. You'll learn so much from that experience that any subsequent removals will go much quicker. Regardless, it's not hard to pull the gearbox back and into the passenger compartment for removal. It is helpful to have an assistant when you physically pull the gearbox backwards and when you are ready to re-install the gearbox on the splines.
Bona42na
Bona42na
Thank you Andrew and Doug for that valuable info. Interior was just redone. Atleast now I can fully inspect the floor pans while the carpet is removed...
THANK YOU
R TR2/3/3A Removing transmission Triumph 3
KVH TR4/4A Removing Front Transmission Seal Triumph 1
nevets Removing carpet from transmission tunnel Austin Healey 15
KVH Removing the Transmission Triumph 16
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
philman Wedge Removing TR8 engine+transmission Triumph 10
RobT TR5/TR250 Removing the Transmission on a TR250 - any tips? Triumph 9
Johnny Removing Overdrive from transmission. Austin Healey 1
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
K TR2/3/3A Removing windshield stanchions? Triumph 8
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
