TR2/3/3A Removing TR3 windshield stanchions
karls59tr
Bronze
Non Dzus stanchions. Been on there for 64 years! What is the best way to free up the hold down screws? It looks like a PO has already bodged the slots in the screw heads so it may be hard to get a large screw driver to fit there. Any ideas.:unsure:
TFB
Kroil penetrating oil is my favorite.
Soak from front and under dash.Get screw driver that fits perfect even if you have to grind a large one to best fit.
Shock.Give the screw driver some sharp blows.Lastly some heat to the mounting plate under the dash.An impact driver may also help.
Good luck
Tom
TomMull
No magic I know of and those things can be difficult. Good suggestions above.
If the screw slots are badly damaged, do the best you can with a dremel or die grinder to get a screwdriver to fit. One advantage of an impact driver is that the screwdrivers that came with mine were wide enough and fit the slot very well.
Tom
K
karls59tr
Bronze
Tom
Thanks for the info Tom
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
J TR2/3/3A ? on removing tr3 starter? Triumph 16
M TR2/3/3A Removing and replacing distributor in TR3 Triumph 15
K TR2/3/3A Removing the water pump on a TR3? Triumph 11
D TR2/3/3A Removing TR3 'starter' bolt Triumph 3
tinman58 TR2/3/3A Removing head studs TR3 Triumph 15
B TR2/3/3A Tr3 removing front wings Triumph 8
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
ekamm TR2/3/3A removing tr3 instrument panel Triumph 15
Number_6 TR2/3/3A Removing front fenders on a TR3 Triumph 20
CCURTISS Removing Seat Track Screws TR3 Restoration & Tools 3
Tinkerman TR2/3/3A Removing Fabric From TR3 Dash Panel Triumph 7
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
