TR2/3/3A Any trick to removing TR3 doors?
lordwestbrook
Hola folks!
SO- I need to remove the doors on the 3 to get to some bodywork and the screws holding the hinges are frozen pretty good and wont budge even with liberal PB Blaster. I've already had 1 square nut backer thingy spin free of its backing so I dont really want to twist anymore on the screws... So the door pins- Is there a trick to getting them out? (They're pretty frozen as well)
Any advice of course is appreciated.
Cheers!
Jeff
sp53
I doubt you will get the hinge pin out, but maybe with a porto power, but a good chance of doing real damage to area. I have used impact hammers that you **** to loosen or tighten. And I have drilled the heads of the screws as well, leaving the stud part in the post until I had the fender and door off to hold the nut cage with vise grips on the A post. The impact hammer usually does it. Turn the impact tool to loosen and get a nice fitting slot headed bit and hit it with about a 3 pound hammer. The force of hitting the hammer and having the cam spin that little bit counter clockwise usually does the trick
DavidApp
As the screw/square nut will get plenty of water mud etc thrown up on them if the guard between the wing and firewall is missing they are often very rusty. Also depending on how long since they were installed and how much anti seize was used removal could be tough. The impact driver can help as the impact + turning can get the job done. I did not face the problem because the PO had done the disassembly for me.
Have you tried the door screws they may be easier? If that fails you may end up having to drill the heads of the screws. Can you get a pair of locking pliers on the nut that is turning. It is tight in there.
David
DavidApp
A screwdriver bit in a 1/4" drive ratchet may help as well. Give you more torque while you can apply pressure to hold the screwdriver in the screw head.
David
charleyf
An impact driver is what I had to use to get mine loose. Though it is harder to remove the screws from the door side you can get to the back side with your choice of lubricant ( inside the door). On the front side I believe that you can also remove the splash guard and spray lubricant onto the nuts on the backside of the A post. Once the door and fender are removed you will also have access to the nuts / nut holders behind the A post to correct any damage you incurred in getting the screws out. Actually better access than the nuts inside the doors.
L
lordwestbrook
Thanks everybody- Good to know I have options, and I'm not beating the door pins to death to no avail. I'll just keep cracking away at it- Charley the fenders are off (well mostly on one side as I just cut the rotted fender off with a wheel) Persistence and more lube (there's a joke in there somewhere)
CJD
Drilling out rusted bolts is, unfortunately, part of the fun of working on these cars. On average, for the 14 screws you are Working on, about 4 of them will have to be drilled out.
There are 2 type hinges. The early design is all brass, while the later is a stamped steel affair. I haven’t had any luck removing the pins from either, even with the hinges removed from the car.
charleyf
If you are actually trying to drive the hinge pin out, why don't you just use a cutting blade on a 4&1/2" grinder and cut the hinges at the pin? I would be concerned that you might deform either the door or the A post while banging on the hinges.
Graham H
I think the hinge pins are riveted to hold them in, carefully drill the top of the pin and you can then drive them out but I would try the door side bolts first. Heating them is another option?.
Graham
JAJohn
Member
Bronze
Had the same issues with mine. All the screws had to be drilled out. the cages were total rust and got mangled. Now can someone suggest an alternate to caged nuts?
DavidApp
I think one of the reasons for cage nuts is to allow for some adjustment as you fit the door. Several vendors sell cage nuts.
David
CJD
Not a good idea. When you try fitting the parts you will see why. You have to loosened and tighten those bolts many, many,...did I remember to say...many times doing a door or fender installation. If you have to have a helper holding the nuts from behind it will delay the assembly a lot. The caged nuts allow you to do it quickly and alone.
The problem is not the cage nuts, but rather the fact the factory did not paint or use any rust preventative during the build. If you paint your cages and use a good rust preventer, like LPS3, it will be another 50 years before the nuts seize to the bolts.
DavidApp
I did find that some of the cages I bought were not a good fit for the nut. Some even allowed the nut to fall out. I got in the habit of reforming the cages for a better fit before I welded them to the car.
David
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Jim_Gruber Removing Aluminum Channel on top of door - Trick? Spridgets 5
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
Basil Neat trick for reading oil level Restoration & Tools 7
N TR2/3/3A Cheap trick Triumph 5
Graham H TR2/3/3A Randall's Trick Triumph 10
S Ramps. What's the trick? Spridgets 23
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
S Trick or Treating Spridgets 5
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
S So, what's the trick... Spridgets 17
T TR6 tr6 water pump trick? Triumph 4
H Trick needed - for body curve Austin Healey 12
Henson80MGB Trick to remove rubber hose to Slave Cylinder? MG 19
C Trick Midget Mk1 Racecar Spridgets 15
P help: trick to snap and unsnap soft top ? Triumph 11
glemon 11/64s drill bit tranny mounting trick Triumph 10
M Weber Carb trick Spridgets 1
BOBBYR Trick question . See what you think. Austin Healey 10
W A neat trick Spridgets 1
Jim_Gruber Rinstalling Beehive Lamps on BE what is the trick Spridgets 7
RickB Any trick to replacing shackle bushings? Spridgets 5
J What the trick to the steering column bushes? Triumph 6
jlaird Very slick trick Spridgets 3
zimmy my new clutch bleeding trick Spridgets 10
W New or another ebay fraud trick Triumph 8
jlaird For my next trick Spridgets 5
J So what is t he trick for getting the ujoints out? Triumph 3
J Any trick to getting the bump stops off Triumph 14
P Nut and wire Trick Triumph 9
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
aeronca65t MGB Semi-trick MGB MG 7
G Out with the rubber-hose-to-the-ear trick..... Triumph 10
RobSelina what's the trick to getting a steering wheel off? Spridgets 36
tomshobby Kind of a neat trick. Triumph 4
aeronca65t Trick Pontiac GTO Other Cars 3
A Spitfire Trick to remove 78 Spit carb? Triumph 4
G Neat trick Triumph 5
Alan_Myers TR2/3/3A TR2/3/4 cooling trick? Triumph 1
Z Rope trick works! Triumph 10
J Exhaust Valve - dollar bill trick! MG 20
Steve Secret door trick MG 1
Basil Rope Trick Triumph 2
tr6web TR6 Need advice removing downpipe nuts Triumph 4
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
