TR4/4A Composite vs cooper head gasket with Randall's "trick"
tdskip
Is one vs the other more likely to work if my liner protrusion varies between .002 and .005? Hoping to do this once, without taking the engine apart, and get back to driving the car!
Thanks.
TR3driver
Great Pumpkin - R.I.P
My understanding is that the solid copper gaskets are hard to keep sealed. Mordy actually sells a special adhesive spray, that they developed to keep them sealed on the racetrack (where it only needs to work for a few hundred miles at most). I've heard that "Yammabond" (from Yamaha motorcycles) works too.
Just for clarity, I used a standard composite gasket for my "trick", and it was standard composite gaskets that weren't staying sealed for me. I've not tried one of the solid copper ones myself. With the trick applied, I've even reused the gasket and no leaks.
T
tdskip
Ah, OK, best of both then.
Randall, is the spacing of the cooper wire from the opening critical? Height of tack weld critical?
Yes, only want to do this one last time but also documenting for the forum and future users.
Thanks!
TR3driver
I'm not sure how critical the spacing is. Obviously it has to be on top of the liner; and I chose to put it in the slight depression just outside of where the copper sheet from the other side is folded over. But I wasn't particularly careful about making sure it was right against the edge of the sheet. Here's a closeup
The "tack weld" is just soft solder. (Kester 63/37 eutectic rosin core, just because that's what I had on hand.) My assumption is that it will deform and flow under the clamping force from the head, so I didn't worry about particularly making it even. In fact you can see in the photo, it was a fairly lousy soldering job. The idea was just to ensure the wire staying in place while the head was installed. (I did go back after the photo was taken to cover up the ends, just wanted to show how they were overlapped slightly.)
FWIW, Ken Gillanders (BFE) suggested using super glue instead of solder. Makes sense to me, but I stuck with solder since it worked so well for me before.
Also FWIW, this time around I used "Tarn-X" to clean up the copper surface before soldering. Lots less work than shining it up with Scotch-Brite or steel wool, and seemed to work fine.
TR3driver
Sorry, I can't help you there. That isn't a standard gasket, doesn't appear to have any copper at all. Most likely solder won't even stick to the "fire ring" portion around each cylinder (looks like aluminum to me). But since the ring appears to be pretty thin and located well out on the liner, it may seal OK without the "trick".
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
BobHaskell Mini Cooper rear subframe replacement British Motor Corp 3
K MK1 Cooper S? British Motor Corp 3
tahoe healey Cooper Air Filters Austin Healey 7
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
Sherlock Mini Cooper patina Spotted 0
J 2006 Mini Cooper S British Motor Corp 6
M Cooper's Air Filter on H1 Carbs Spridgets 5
tahoe healey Cooper decal on air filter Austin Healey 2
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
David Townsend MK I, MK II, Cooper S Limited Edition Fine Art Prints British Motor Corp 0
G help with a part Id. cooper air cleaner? Other British Cars 1
R Tyres for Mini Cooper British Motor Corp 7
U Mini Cooper S Roadster ! British Motor Corp 1
S TR2/3/3A cooper head gaskets packaged improperly Triumph 6
T Cooper S block needed British Motor Corp 2
C Car of the Week [Mini Cooper S MkII] Racing 2
Brooklands Mini Cooper Pick Up Truck British Motor Corp 2
tr6nitjulius Cooper-S @Dyno British Motor Corp 0
Aggudabbu convert cooper engien for spridget? Spridgets 23
69MGC B with Mini Cooper Headlights MG 9
bgbassplyr Cooper project on ebay British Motor Corp 0
theleisure twin-engined-4x4-1966-twini-cooper-s British Motor Corp 1
HealeyPilot Starter motor replacement - Mini Cooper S British Motor Corp 3
HealeyPilot 1275 Cooper S starter British Motor Corp 5
S 2005 Mini Cooper British Motor Corp 20
Tom Rynne Cooper Decal Spridgets 6
G mini cooper v. cooper clubman British Motor Corp 3
Morris OT: Mini Cooper Spridgets 16
PATR8 Woody Cooper in Classic Motorport Magazine Triumph 1
S Why Mini Cooper vs Cooper Mini? British Motor Corp 10
M WANTED: AUSTIN MINI COOPER British Motor Corp 2
jlaird Cooper cyl head maybe on ebay Spridgets 7
aeronca65t Elf-Buick-Cooper S British Motor Corp 2
C Hi Im a neewbie with a Mini Cooper ! British Motor Corp 4
Prince_Phillip Cooper S Reshell Project British Motor Corp 0
G Clutch shudder problem in Morris Cooper S British Motor Corp 10
T Cleaning a Cooper Air Filter Spridgets 3
M Mini Cooper clutch problem British Motor Corp 2
David McLaughlin Movies! - Jaguar E-Type, Lotus Elan, Mini Cooper and many more! Jaguar 4
coldplugs Super-Cooper? British Motor Corp 6
J 64 Mini Cooper British Motor Corp 3
78Z Nice article on new Mini Cooper S British Motor Corp 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
