TR2/3/3A The thread pitch of the cylinder head studs?
karls59tr
Bronze
Does anyone know what it is? I'm ordering new head stud nuts and Summit Racing wants to know.
K
karls59tr
Bronze
New nuts on OLD studs??????????????????
Mad dog
Yah I know. I dont want to risk removing the rear studs to replace them with new ones because I think doing so will just make the existing hairline cracks on the block bigger when doing the install.:unsure: I'm thinking just new nuts will "at least help" to get a better seal on a new head gasket. I saw a father and son team that were doing a rebuild on a TR4 engine and they could not get 3 studs out of the head so they opted to just go with new ARP nuts and it worked for them. I am going to replace the block with a spare one at some point but for now I want to try one more time to get the gasket to seal so I can at least get one more summers driving out of the car before doing a major tear down and block replacement in winter. :smile: Do you happen to know what the stud pitch is?
Sarastro
They are 1/2 UNF, which is 20 threads/inch. You also should be CERTAIN to get grade 8 nuts and washers.
That said, I doubt that new nuts will help. If you can torque the old ones to spec, what's the difference between new and old?
K
karls59tr
Bronze
I've heard Grade 8 bolts could crack the block? What grade is the stock nut?
mctriumph
Sick idea, set the new studs with epoxy in the cracked areas. The force of tightening the stud
will push the epoxy into the cracks. Then you have new studs that can be torqued accurately.
If your block is the problem(?) this can hurt nothing. Metal bonding epoxy will handle the heat just fine.
Chase the threads where the issue is, coat the studs and set them in place.
Mad dog
K
karls59tr
Bronze
Mad dog
That sounds like a plan. :smile: (y)(y)
GeneJohnson
Unless there is some new epoxy I'm unfamiliar with, many epoxy resins soften and is unusable at boiling point of water, 100C /212F. I wouldn't recommend using it on most anything engine compartment related, particularly the engne.
Sarastro
That's just not true. Look at ARP hardware, for example; it's actually much stronger than grade 8.
If you work it out, you'll find that the tension in the head stud is actually close to the yield strength of a grade 8 fastener. That's why you MUST buy good hardware, grade 8 or better. Do those cheapo studs made in Indonesia somewhere really meet grade standards? Perhaps, but I wouldn't blithely assume that they do.
mctriumph
Gene, metal bonding epoxy is good to 300F+. We all hope and pray to keep things cooler than
this at all times, lest bad stuff happens.(catastrophic failure).
Mad dog
CJD
I have tossed many stock studs because they would not torque to spec. I feel they are right at the edge of being acceptable. Also, the original nuts are taller than available nuts, aren't they? I've never had an issue with stock nuts. Washers should be hardened and ground for flatness.
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
M What thread pitch to use Triumph 38
T TR2/3/3A thread pitch for TR3 water tap in block Triumph 4
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
L What size and thread pitch oil drain plug? Spridgets 5
B thread pitch grill brow Austin Healey 1
SS_MGB T-Series Thread Pitch MG 7
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
J Thread Locker on Shock Bolts? Austin Healey 19
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
rvm Annulus shaft thread measurements? Austin Healey 12
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
B General Tech Waking up a sleeping car thread MG 1
JimLaney Anti-seize or Thread locker ? Spridgets 2
W TR2/3/3A Glaciers move faster - my build thread Triumph 0
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
B Stripped Thread in Gas Tank Austin Healey 26
J anybody tell me why this thread closed? Austin Healey 4
T TR2/3/3A Another wheel bearing thread Triumph 5
Boink Waterless Coolant - thread from the AH forum Spridgets 18
Rut TR4/4A steering shaft/nut thread size Triumph 5
