General TR Plenty thread left on my old OEM 185 Redlines
tr6nitjulius
Couple months ago new 1st time owner of TR6 said new tires on his parts list for his '72 passenger side rear had blow out on fwy TR6 did 360 ended facing the opposite way, lucky not much traffic on fwy, right rear panel/broke drum off trailing arm assy said knew he needed tires but he was trying to get one more day out of old OEM 185 redlines
From fb:
https://uk.motor1.com/news/681177/triumph-tr7-tyre-blowout-caught-on-teslacam/?utm_source=flipboard&utm_content=topic/tesla&fb clid=IwAR0jTjse1bhltDcixKme6OZy8sHKPQeOQG_vHS4NyCh ZdYiTSncUf4LrUEg
Gliderman8
I had a tire blowout on the Pennsylvania Turnpike in the late 90's. I was doing about 60mph and ~wham~.... my left rear blew out. The rear of my Ford Explorer was fishtailing all over the place. I was lucky to get it under control. Very soon after that the news was reporting a rash of Firestone blowouts on SUV's. Firestone did replace ALL of my tires in a massive recall. Initially they only wanted to replace four but I was emphatic that they replace the full size spare as well. The Firestone dealer did give me some pushback but in the end, they did replace all of them.
Blowouts are scary :eek:
mctriumph
Cant make it up ! Had an old Michelin explode in the shop spontaneously. 67 MGB in for a resto, walked away and BLAM, like a 12 gage,
laid the belts out all over the floor. This was after it was aired up to 22 psi to roll inside. I tell everyone steel radials are not trustworthy
after 10 years regardless of miles. Not worth your life!!
Mad dog
tr6nitjulius
tr6nitjulius
Loved them new for the OEM look, hated the ride/handling/lack of grip/performance, any time I see TR on them in person or pic inform the owner of the dangers, look good, last forever, no visual tread wear but hard as a rock, dangerous to ride on you're taking a very high risk with anytime you drive & my good conditioned couple yrs old 185 redlines TR6 was like on skates during panic stop. Still sport Redlines but on modern day tire
TFB
Once they start to get old and hard and cracked they also get slippery,which will increase stopping distance,which is my biggest concern on a vintage motorcycle.
I hate changing tires that look like new tread wise but display compound deterioration with cracking,but whats your safety worth?
Ever have a flat on a motorcycle?Just one will change your outlook about running old tires.
I was happy to replace the last set on the tr3 because I wore them out.
Tom
B TR6 First-time TR6 owner, plenty of questions.. Triumph 9
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
C My 2500M progress/questions thread TVR 5
JFS Wedge Stripped gearbox filler hole thread Triumph 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
charlie74 Wanted Thread restorer kit Triumph Classifieds 0
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
J TR2/3/3A such strange thread on gear shift knob Triumph 12
J Thread Locker on Shock Bolts? Austin Healey 19
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JPSmit Spridget thread question FORUM Navigation Questions 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
Editor_Reid Parts List Thread Now "Sticky" - parked at the top of this list of subjects Austin Healey 0
Boink Rolls-Royce head replacement thread... Other British Cars 0
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
rvm Annulus shaft thread measurements? Austin Healey 12
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
nevets How do I unsubscribe to a forum thread??? FORUM Navigation Questions 2
B General Tech Waking up a sleeping car thread MG 1
JimLaney Anti-seize or Thread locker ? Spridgets 2
W TR2/3/3A Glaciers move faster - my build thread Triumph 0
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
B Stripped Thread in Gas Tank Austin Healey 26
J anybody tell me why this thread closed? Austin Healey 4
T TR2/3/3A Another wheel bearing thread Triumph 5
Boink Waterless Coolant - thread from the AH forum Spridgets 18
Rut TR4/4A steering shaft/nut thread size Triumph 5
Editor_Reid New "Parked" thread at the top Austin Healey 0
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
B TR2/3/3A end of me water pump thread Triumph 2
Elva164 Michael's Vintage Racing video thread! Racing 5
JPSmit Following the Car Tunes thread - "spotted" Spridgets 4
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
