TR2/3/3A Thread and size for tr3 fuel tank vapor line fitting
DennisT
Hi,
does anyone know what type thread and size hole is on the top of the fuel tank for the vapor line fitting, I need to buy a right angle threaded/ barb to hook up a vapor line. The car had the incorrect pipe thread fitting.
Thanks
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
J TR2/3/3A TR3 exhaust manifold stud thread size? Triumph 3
J TR2/3/3A TR3 - Lower Fulcrum thread size Triumph 4
toysrrus TR2/3/3A Need Help with a "THREAD SIZE" for a TR3: Triumph 23
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
CARSINC Spark plug thread size Spridgets 2
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
Rut TR4/4A steering shaft/nut thread size Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
Andrew Mace Off Topic MGB taillamp base thread size Triumph 6
L Thread size, indicator head to stator tube screws Austin Healey 0
W What size taps and dies for thread cleaning ? Austin Healey 7
I Thread size for speedometer stud? Spridgets 4
PAUL161 Gear Shift Lever Thread Size? MG 28
kurts100 Thread size on Fulcrum Pin Spridgets 7
I TR6 TR6 oil sending unit thread size help please? Triumph 12
H TR2/3/3A Oil Sump Thread size TR3A Triumph 4
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
L What size and thread pitch oil drain plug? Spridgets 5
angelfj1 Speedometer Retainer - thread size please Triumph 20
I bugeye brake union thread size? Spridgets 2
Atrus Oil Pressure fitting thread size [calibrate gauge] Spridgets 15
mountainman Thread Chaser Size Triumph 7
CraigCootsona Thread size for 1275 coolant passage Spridgets 10
R Gear lever thread size Austin Healey 2
apbos Fulcrum pin thread size. Spridgets 7
T TR6 egr thread size? tr6 Triumph 6
VelodromeRacer Thread size and pipe size for steel clutch line... Spridgets 2
John Moore Shifter Knob Thread Size Spridgets 3
chrisc Wedge TR8 Air Pump Injector Thread Size Triumph 11
emann Steering Wheel Thread Size Spridgets 11
2wrench Describe thumb nut size and thread on speedo stud Triumph 26
J Bump stop thread size? Triumph 2
S Spitfire spitfire axle thread size? Triumph 6
I thread size for oil sending unit Triumph 5
D bolt thread size 100-4 Austin Healey 1
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
J Next Thread? FORUM Navigation Questions 1
L Little1's 75 Midget 1500 Thread Spridgets 14
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
NutmegCT Change amount of posts shown in a thread. FORUM Navigation Questions 0
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
