    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR6 Bolt size/thread count for fuel sender TR4/TR6
tdskip
Well so much for the idea that I was diligent on packing and labeling everything.
Anyone know off hand the thread size/count for the thread that are used to secure the fuel sender to the tank by chance?
Moss #323-370 or #28 in the schematic below.
Thanks!
DNK
I have em out in the garage in a bag if you need em!
TR3driver
Great Pumpkin - R.I.P
Stanpart TR6504, which is 10-32 by 1/2" long.
DNK
10/32's X 3/8s oval head straight tip.
Copper washer?
T
tdskip
Man is it ever nice to be putting something back together for a change. The 10/32 worked a treat guys - thanks again!
Gliderman8
Yep... I concure... 10/32's is it!
DNK
no, each of them little screws has a fiber washer
TR3driver
Only fiber washers on mine are where the bolt/stud for the wire passes through the plate. The bolts that hold the sender to the tank only have internal star lock washers (P/N WN0705) per the SPC.
DNK
all of mine has a small which I thought copper washer. The diagram Tom posted list a fiber washer
TR3driver
In the immortal words of Emily Litella:
TR3driver
Apparently TR4-6 did have fiber washers, TR2-3 had lock washers.
My bad.
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
D bolt thread size 100-4 Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
GeorgeC BN1 bolt size Austin Healey 0
MY66AH Bolt head size Spridgets 2
K TR4/4A Clutch pressure plate bolt size? Triumph 1
K TR2/3/3A Gearbox bellhousing to motor bolt size? Triumph 12
S TR2/3/3A starter bolt size Triumph 4
R TR2/3/3A Floorpan to frame bolt size Triumph 4
K TR2/3/3A Proper size of "set screw/bolt?" for top of trans..... Triumph 1
Geo Hahn TR4/4A Crank Bolt Size Triumph 5
tri_carb_healey drain plug bolt size 3000 bt7 Austin Healey 6
Newkie Center Console Bolt/Screw size? MG 1
doughairfield Bolt size for the bonnet Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Fan Extension End Bolt Size Triumph 20
A TR2/3/3A TR3 generator mount bolt size Triumph 4
H TR2/3/3A TR3 Generator Mounting Bolt Size Triumph 5
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
neilh Cd150 Carb bolt size Spridgets 5
S Front pulley bolt size? Spridgets 2
jhorton3 Bolt Size for Hood Spridgets 6
Steve_S Bolt Size Question MG 6
T What size bolt to secure handbrake assembly? Spridgets 12
Cain Wiper Motor Bolt Size Triumph 0
KLUTZ Bolt size for splash panels? MG 5
V8Blazer bolt size? MG 0
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
W Wanted Bolt on luggage rack Triumph Classifieds 4
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
