General Tech Dog Bolt Torque—Crankshaft
KVH
I’m not finding a torque spec in my manual. I know it’s supposed to be 100 foot pounds or something like that, but where is that stated? Also, just wondering—would 90 be enough?
100ish sounds about right. There is some leeway as on the TR3 you have to end up around the 10:00 - 4:00 position for ideal hand cranking. Some of that is controlled by shims and then some fine tuning that affects the amount of torque applied.
I believe the internet settled on 100+ ft-lb; I’ve seen 120-140, 75-140, and “north of a ton”.
I set mine to 140, on the high side but used loctite, which reduces the friction.
Remember to use a six point socket. The bolt is rounded off by design - not sure why.
I believe it’s rounded to provide forgiveness while hand cranking in case it kicks back to provide some protection to the poor mug who has to try to start his car that way…
The Service Instruction Manual for the TR2 (Incorporating supplement for TR3) states on page 13 under Nut Tightening Torques that the value is 140 foot pounds.
I torqued it to 90. It seemed so tight I got worried I’d strip the crank threads, and couldn’t imagine it coming loose.
I usually pull one up tight with a 12 to 14-inch breaker bar and then place a 6-point knock wrench on it and give it a smack with a 3-pound hammer. The one on my car now has been on it for ten years and has never come loose. I also, never reuse the spring washer and put a new one on each time. PJ
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
T TR4/4A TR4 Fan Extension Dog Bolt Torque Triumph 4
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
B TR4/4A Starter dog bolt Triumph 15
KVH General TR Front Dog Bolt and Fan Balancer Piece Triumph 1
K TR2/3/3A TR3 starter dog bolt removal.... Triumph 9
C TR2/3/3A removal of dog bolt for crank start tr-3 Triumph 10
Tinkerman TR2/3/3A TR3 Crank Dog Bolt & Double Wire Clamp Question Triumph 5
Tinkerman TR2/3/3A TR3 Cranking Dog Bolt Position Triumph 6
rlandrum Dog Bolt Removal Triumph 32
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
vette MGB Rear Fender Dog Leg Patch Panel MG 3
D TR2/3/3A TR3A Crank Dog Triumph 2
H driving dog [gear] for distributor? Austin Healey 17
GTP1960 TR2/3/3A Restore project Drove my dog to drink! Triumph 1
K TR2/3/3A Distibutor drive dog pin removal? Triumph 8
PatGalvin TR2/3/3A TR3 PS Quarter Panel Dog Leg needs a good home Triumph 2
S TR2/3/3A tr3 leather cockpit capping dog leg Triumph 4
T TR2/3/3A tr3 dog leg replacement on pre-60k Triumph 4
V Dog? Maybe not Triumph 4
Superwrench Dog leg on 3000 Austin Healey 5
JohnnyMead TR2/3/3A Trimming the Dog-Leg Capping on a TR3 Triumph 9
RickB Beautiful Fall day in NW took the dog for a ride! Spridgets 17
jlaird Dog gone it. Spridgets 11
aeronca65t Corolla Hot Dog Other Cars 10
M Distributor Drive Dog Removal Triumph 8
G Now how exactly do I make a drive dog to prime oil Triumph 8
jlaird Out walking the dog this morning early Spridgets 2
D Those red dog legs...Beware MG 5
D Dog leg fit MG 6
bluemiata90 TR2/3/3A Like a dog chasing it's tail ,,,TR3 troubles Triumph 17
G NEED A QUICK ANSWER...setting drive dog for dizzy Triumph 8
pcanonge Dog food for Kitty? Jaguar 10
jlaird You know it is the Dog days of Summer when Spridgets 2
jerrybny Felt Like a Hot Dog in a toaster oven today. Triumph 10
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
S dog leg repair panels Austin Healey 6
kch Cranshaft nut/starter dog-tighten ? Austin Healey 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A old 4 bolt axle differential. Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
