NEED A QUICK ANSWER...setting drive dog for dizzy
G
OK, I got the new oil pump in this afternoon and plan on reinstalling the whole sheebang tonight. Now, I had removed the distributor, the distributor base and the slotted drive plate that engages the cam and drives the oil pump on the bottom and couples the drive dog on the dizzy on the top. In other words, my timing is now up for grabs. The Bentley says to set the crank on 4* ATDC (did that) so that the #1 cylinder is in firing position (the cylinder is up to the top of the bore - looking through spark plug hole); then it says to set the cam-engaging geared drive plate so that the offset drive dog slot is offset towards the engine. The illustration shows the slot should be in line pretty much with the two opposing holes in the dizzy base, one of which holds the dizzy down with a bolt off the adjustment plate.
The question is...IS THIS RIGHT (my mind is in a fog right now)? There is no way it will line up perfectly with the two opposing holes in the base, but the one alignment that seems best has the slot in the drive plate more parallel with the engine, which is pretty much what I think I should shoot for.
This will all dictate me getting the timing right so it is important to get it right. Yes, I know I did this before, but right now I am so darn gunshy that I just don't need another meltdown.
Re: NEED A QUICK ANSWER...setting drive dog for di
If the pump is in place and the engine is in the FIRING position (there are TWO times the crank is in #1 TDC for every hole, y'know) try turning the oil pump drive to approximate the place where the dizzy drive will engage it when it is oriented properly.
...BTW: you're using an electronic iggy IIRC?
Bill, you could always pull the valve cover
off- if you are not certain when the piston
is TDC in the FIRING position. Even know almost
nothing me can now do that one!! LOL
d
As close as you can to the image in the Bentley. Sounds like your on the right track though. Understandable second guessing yourself, but stop it. Clear your mind and work confidently.
Just watched one the head mechanic at a local LBC shop freak out his lead mechanic with a simple question today in regards to a freshly rebuilt TR3 engine. He asked him if he was sure the rod bolts were tight and torqued. Remember, this is when the engine is already off the stand and being readied for customer pick up. The lead mechanic freaked out so much that he pulled the sump to check. Only to find that everything was fine. The whole time the head mechanic was in the corner snickering. That sort of thing qualifies as a mild practical joke with that head mechanic.
That's kinda sadistic, Shawn! Though I've been in BOTH situations. Best advice is what you've already said: "Clear your mind and work confidently."
AMEN!
Yep, I was snickering with him but only becasue I have been on the other end several times and new what he was doing. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
We've likely got dozens of parallel "terror in an eyeblink" tales... it'd be fun to sit and natter a bit.
Meanwhile... Where's that DENTIST?!?!
Gotta eat. Go back later.
You're gonna be useless inna office t'morrow....but you may arrive in a TR6!!!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
RJS Radiator Fan Bolts - need quick help Triumph 4
Coyote1 Need a quick measurement Triumph 7
N Need some diagnosis help quick! Triumph 12
crya QUICK-Need Help w/ Interior Color Combos Austin Healey 6
C TR6 I need a little help....quick measurment on a TR6 Triumph 2
G I need a quick tutorial on Whitworth wrenches MG 6
Got_All_4 Wedge TR7 Speedo Problems Need a Repair Place Triumph 2
M For Sale 6.0 harmonic balance need rebuilding Jaguar Classifieds 0
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
