Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo
volunteer
This is a 1971 Daimler but of course built by Jag. I need a supplier or possibly a link to a repro manufacturer. Thanks.
LarryK
Is this the same body as an XJ6 or 12? If so, Moss, SNG, Welsh, Engles, and RockAuto have them.
volunteer
volunteer
This is a huge vehicle - possibly same as Jag 420? Parts not rare due to being Daimler - but rather from being so old, and mundane. I need confirmation of cross-overs, interchangeability, super-cedes etc. thanks.IMG_2551.JPG
LarryK
Try Martin Robey, they have seals. Real nice people, have used extensively.
volunteer
volunteer
Thanks for info. I know of this place but difficult to connect with. I sent email describing items and awaiting response. P.S. do you or anyone else happen to know where brake light switch is located (on '71 Daimler Limo (RHD)?
LarryK
If you don't have international calling, it costs .15 a minute to call. I never spent more than a $1 as they understand costs. Wait on email, they are 8 hrs different than east coast and there weekends are before ours. Good people. May be back logged as they serve the world. Their place is between the Jag and Rover factory.
volunteer
volunteer
Well they did get back to me. Good news is that a rear suspension bush is available, and, the trunk seal - but no luck with the vent windows and door seals. Prices apparently good but I expect high shipping costs plus (CDN) import taxes and very high exchange rate. ie: 20 British pounds = 35 CDN $. But, glad to have available. Now some more searching for door seals - but likely looking to take a 'hit' when limo goes up for sale. thanks.
LarryK
I bought 300 lbs of body repair panels for my MK1 at Martin Robey. $400 UPS, $100 import fee, no tax. Came to door in a week. They should mail what you need, but probably UPS. If you have an import fee, UPS calls you. I also deal ebay.uk and they let you know shipping and fee ahead of time. I have bought a lot of seals thru ebay.uk. just watch for the 100% sellers or near 100%.
volunteer
volunteer
Thanks for info. It's much worse to order stuff into Canada and UPS worst shipper as they like to double dip once parcels cross the U.S. border. I will shop around as I await yet another reply from M.R. Good thing I don't need any engine or fuel system parts. Now, how to remove the right/rear saddle tank and await warmer weather to get to the wooden dash pieces, etc. etc. :greedy_dollars:
LarryK
You might have to take bumper on right off. Remove lower fender panel and unbolt tank from inside boot. I am assuming same as the XJ6 series cars with independent suspension. Tank may have drain and fuel lines go thru inner boot to tank.
volunteer
volunteer
Getting used to new format. Thanks for all info. Seller (jumpinjag) on ebay.uk offered all the door and window seals, plus the felts, for 825 (U.K.) including shipping. No trunk seal. Cost to me would be converted to about $1500. cdn. so not sure what to do. At least stuff still available but leaning towards letting next owner take care of it. Will get trunk seal and soft bushing from M.R. - estimate $60. to $65. so not too bad.
Fuel tank has bracket which also secures jack and spare tire. Tank will 'wiggle' but not slide up and inward I suspect due to layer of black protective material. At least both tanks / pumps / sending units functioning as they should - after hours and hours of TLC. Still need to find brake light switch or whatever triggers. thanks for all interest.
volunteer
volunteer
Well, I got the parts delivered March 11, so took full week (door to door). This is what it cost me. The two items were a combined 21 UK pounds - - which converted to $36. (CDN) which is pretty good. Then, with taxes, shipping and handling - culminated with handing FedEx driver $15. cash on delivery, my total (out of pocket) came to $115.(CDN). The car is only worth (optimistically) about $16K. so hopefully will end up back in its' 'birth-country'. Oh, bushing and boot-lid seal look super, so Martin Robey (thanks to Kevin) did their part very well.
Now - - someone please tell me where to look for brake light switch? :unsure:
LarryK
Either on brake pedal arm or behind master cylinder or on master cylinder.
volunteer
volunteer
Browsed thru British Parts Northwest (Oregon) and noticed the fuel tank seals and locking rings (that attach gauge sender unit) - at a very fair price. Two of each totaled less than $5. Then I check out other costs, with shipping being $43. I added extra taxes and duties (to Canada) then converted to CDN $. The final (door to door) out of my pocket will be in the $80. range - or even higher. I contacted the dealer for possible alternatives and suggested putting all four tiny, non-fragile items in small bubble-pack envelope and (snail) mail with whatever postage. With the extra charges as above, total would/should be closer to $20. I haven't received a reply yet after 24 hours. (NOW - as of May 01, still no reply.) :unsure:
Also, still haven't located the brake switch as everything between pedal arm and MC is trapped in upper compartment. I will try to find a schematic and trace thru wiring, but these old jalopies were famous for one -color wiring. Oh, and any ideas for re-coating wooden dash panel pieces? Stain with varnish mix, or separate? Brand? Name? Best or easiest way to apply? etc. thanks.
LarryK
They are not one color wiring, might have to scrap to see color. Is there a two prong switch screwed in master cylinder? Might have to be a contortionist to get under dash. Never been in the Daimler, but might be near a late 420.
volunteer
volunteer
No switch or wires to M.C. I am very slow to gain any progress as too many issues, projects and routines in the way. I did get the locking rings and seals from U.K. cheap and fast. Will make up a 'tool' to turn the rings but, alas, when and how (sigh). New issue is the left side SU fuel pump leaking at diaphragm flange area - no matter how well sealed and tightened. The parts appear to be (dare I say) original so flex part quite stiff. I see other (new and used) pumps for sale - but what about interchangeability? Visually the same (MGB, etc.) and I am not sure about PSI. There is a New Zealand made pump (no.15LM12) on Ebay (U.K.), for about $150. total - my cost - that seems to have same in and out banjo connections and is rated at 3 to 4 psi. Any ideas or tips? What should I be looking for (again, 1971 Daimler DS420 with common Jag 6-cyl. ) Also a diaphragm/stem with common 6-holes in Houston for about half the other price. I will remove old pump, yet again, to see if easy enough to access diaphragm. thanks. Update: (May 03). I did remove diaphragm as it simply unscrews. Found a couple on Ebay - one with 3-inch stem and other with 2-3/8" (same as mine). Now awaiting confirmation that this one has threads on tip of shaft - which I suspect it will as ad photo was inconclusive.
volunteer
volunteer
Spent 50 of last 70 days in hospital. Highly recommend that every man, woman and child undergo open-heart surgery. :nonod:. Just kidding, of course! Worst experience of my life. Easy to get to the Gates of He ll but slow to return. :devilish:. Now 7 weeks since the dreaded surgery and feeling well enough to re-assess what still needs to be done on Daimler. Totally forgot how all the rear seat area goes back together. The diaphram I mentioned previously did not want to screw back into solenoid part but eventually did. There was a weird looking white, plastic piece that was sandwiched in-between diaphram parts so I transferred it over to new part. What I need to know now is exactly how this pump should react when 12 volts applied. Can it be 'bench-tested' with fuel? Please advise. Thanks.
volunteer
volunteer
Still no procedures or specs for SU pump. Got a diagram sent to me by Glen in 'old country'. Didn't take me long to trace the brake lines and subsequently located brake switch at 3-way block - on inner fender panel about 3 inches to right of P.S. pump. It showed no continuity but by-passing unit indeed actuated rear brake lights. I searched and located said switch (under various Jag listings) on R.A. but my cost with shipping and taxes would be about $23. so will try local sources.
equiprx
Have you tried Steel Rubber?
LarryK
Have you tried sources in England? Moss, SNG, ingle Imports, BritParts here. If you want the old Jag/Daimlers done shipping is irrelevant. Only local Jag dealers my get it thru the Vintage Jag supply, or Heritage Parts, but you wait and highest prices. Over 90% of my parts EbayUK.
T Need Help with Door Seals MG 13
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
R TR4/4A Door Handle Question - Need the Wisdom of the Wizards of BCF Triumph 9
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
F Need help finding a part- door window track piece Austin Healey 5
W I need a door panel pattern Spridgets 3
mgnewbie need driver-side door mirror MG 3
eschneider need help - door ID Austin Healey 5
toysrrus TR4/4A My TR4 got "CRUNCHED" Today!!!!! Need Door!!!!! Triumph 46
Jack_Long Need help with door glass MG 2
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
