TR4/4A Door Handle Question - Need the Wisdom of the Wizards of BCF
rnpennington
In refurbishing the interior of my 1962 TR4, I have a problem with the door handle mechanism. After learning of the differences between the handle mechanisms sold by Moss and The Roadster factory and the original handles (All new door mechanisms are for the TR4A and can only be fitted to a TR4 with lots of drilling, tapping screw holes, etc.) I bough a set off eBay that are original to the TR4.
After installing them (whoever came up with the idea of the method used to attach the inside door handle and window handle should be subject to the slow torture of listening to RoseAnn Barr sing the national anthem 24x7 for 10 years), I have a slight problem.
I can open the doors from the inside no problem. However, I cannot open the doors from the outside! I rechecked how I installed them and they look the same as the ones I had on the car before.
Any ideas on what I did wrong? Oh, by the way, I don't have keys for these handles, but I figure I never lock the car anyway, so no big deal.
Let the wisdom flow..................................
Gliderman8
Hmmmm.... I don't know about the TR4 but I seem to remember when I did my TR6 resto that there was a screw on the exterior door handle that was used to adjust the distance to make contact with the door mechanism.
As I said, the TR4 may be different but it's worth having a look at the door handle.
glemon
I believe the lock mechanism lets you push the button on the door, but nothing happens, I also think I have had mine slip to the locked position without having locked the doors (that being said I don't know if TR4 door locks worked the same as the later cars.)
Vila
I just installed the exterior door handles on my 1962 TR4 after having the handles and buttons chrome plated.
With the handle off, could you open the door by sticking your finger in the hole in the door and pressing on the flat metal latch piece just inside the hole?
If you can open the door with your finger in the hole, then it may be the screw on the back side of the button, like Elliot mentioned.
It is a bit difficult to measure the correct clearance and adjust the small hex head bolt and lock nut properly. With the interior door panel off and the window up there is minimum clearance to get your hands in the area to measure and make adjustments. As I recall the spec is to use a .022" feeler gauge between the end of the adjustable screw and the flat plate I mentioned above. It is a little tricky to get the clearance correct and then get the locking nut tightened as you can not see anything and must do it by feel.
If you had the door handles completely apart and are not sure you have them back together properly, then I have instructions on how that is done if you need them.
Charley F from California actually took an old door handle apart and wrote the assembly directions down for me on another Triumph forum.
Visit my personal website at: www.jakegingervila.wix.com/bobs-vintage-cars-
Vila
1933 Chevrolet
1962 Triumph TR4
1984 BMW 633 CSi
R
rnpennington
Bob,
Thanks - the screw adjustment must be the problem, but since I bought the handles off eBay, I would like the instructions on how to put the handle together. I went to the link, but could not find the instructions. Can you send me a direct link to the instructions?
Thanks
alanjohnturner
The key number was marked on the barrels if you have the original ones.
These keys can be cut to order here for just a few bucks. They cut 'em just right by the way.
R
rnpennington
Well, the answer was pretty easy. I installed the door handles basackward. I didn't realize that there was a definite right and left handle, as they were not marked, at least as far as I could see.
NowI know.
i left my notes in the car but I will post how to tell the difference later.
alanjohnturner
They are marked on this little plate:
https://flic.kr/p/i6QUPZ
You can just about see OS and NS in the picture, on the rounded end.
BUT
This is Near-side and Off-side as it would be in the UK.
So in the US the drivers side is the one marked NS.
So you may have got it wrong if if you had seen the marking.
If gets even worse if you build a handle wrong with a mixture of bits from both sides.
Funny stuff happens with the key if you do this. Like you cant lock the car and then get the key out!
PatGalvin TR2/3/3A TR3A Door Handle Key Question Triumph 12
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
nichola TR6 Door handle and window crank installation Triumph 0
F Interior Door Handle Removal Austin Healey 2
T TR2/3/3A TR3A Door Handle Triumph 3
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
C Inside Door Handle Austin Healey 5
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
FlyingCat Spitfire Inside door handle Triumph 2
C 100/6 & 3000 door handle - a puzzle Austin Healey 5
GTP1960 TR2/3/3A Securing Door handle shaft Triumph 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
D Early 100-Six Locking Door Handle Austin Healey 33
Got_All_4 TR2/3/3A Door handle can this bee fixed Triumph 1
B Passenger interior door handle issue [1960 BT-7] Austin Healey 4
J Outside door handle opens but not inside Austin Healey 2
johnrip Wedge TR7 exterior door handle buffer instalation Triumph 3
B 79 Midget door panel and handle woes....help!! [again!] Spridgets 3
P Interior door opening handle position Austin Healey 11
lbc_newbie 1500 door handle caps Spridgets 4
G Door handle Triumph 2
P Outside door handle Triumph 1
Marvin Gruber T-Series TD or TF drivers door handle needed MG 9
K TR4/4A TR4A window/door crank handle removal? Triumph 11
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
B Installing window winders and interior door handle Austin Healey 4
J Door Handle Removal - BT7 Austin Healey 6
L Door handle and window crank escutcheons Triumph 7
M Door Handle Adjustment Triumph 2
memphis remove door handle and window crank Austin Healey 18
Johnny Door handle on BN7 came loose. Austin Healey 8
luke44 TR2/3/3A TR3 Inner Door Handle Parts Triumph 16
D replace outside door handle Jaguar 4
MGTF1250Dave TR2/3/3A TR3A Door Handle Latch Part Needed Triumph 9
martx-5 A Door Handle Story Triumph 3
R Interior Door Handle Removal Austin Healey 4
ronzet BN4 [CE 54767] Door handle picture Austin Healey 9
tahoe healey door handle quality Austin Healey 4
Brosky Easy door/window handle R&R Triumph 3
L '57 longbridge model left-side door handle w/lock Austin Healey 3
P Pin for lock cover on outside door handle Sunbeam (Rootes) 6
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
