TR6 Distributor Gear Mounting Question Need End Float Washer
Got_All_4
Finally got my cam back and reinstalling everything this weekend. Ran into a little dilemma. The distributor drive figure in the Haines manual shows that there is to be a washer between the top of the oil pump bush and the distributor drive gear. First of all what is the process to get the correct measurement for A&B for the thickness of the washer? Suppose to be a 5k end float at A. second is that Moss does not show this washer in any of their illustrations so I would have to believe it is not available at lease thru them 20210528_175224.jpg. When i took it out I don't remember there being one but there are 2 stacked gaskets for the distributor.
charleyf
There is NO washer there. If you look at a manual you will find the process for using a washer to determine what the distance is at that location. Then to get the proper end float distance you use gaskets on top of the pedestal ( location B in your diagram) to obtain that distance. What you want is a space at location A not a washer.
Charley
KVH
Yes, that's correct about the gaskets, but I always wonder how the gaskets could possibly maintain their thickness. Won't a few years of moisture and oil cause the gaskets to vary in thickness and ruin the plan for so many 1000ths of an inch to remain constant? Another issue I always have is getting the pedestal seat to be square so that the measurement is correct and meaningful. With a washer in there, I can rock the pedestal, so how can it possibly be accurate unless we are assured the setup is square to the shaft. Confusing, I know, but I'm not sure how better to say it.
2liter4cyl
Bronze
It is a very thin paper shim, called a "gasket". Moss p/n 697-145. Ill. # 117. Be careful the bolts and the center hole in the shim fit with clearance. The "dummy" spacer should truly flat, and buy shims as req'd.
LeT
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
H driving dog [gear] for distributor? Austin Healey 17
KVH General Tech Distributor Gear End Float Triumph 6
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
B Distributor driving gear orientation Austin Healey 2
R Gear reduction starter hits distributor oil line bolt Austin Healey 14
S TR2/3/3A distributor drive shaft gear Triumph 4
M Distributor Drive Gear MG 10
Dadandson Setting the Distributor Drive Gear.... Spridgets 5
KVH TR4/4A TR4 Timing and Distributor Gear Triumph 3
B B series distributor drive gear. MG 1
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
