MGB New plug wires and distributor cap
Coastalman
Are there any good distributor cap and plug wires to be had outside of Moss Motors? I have been reading about the poor quality of their parts lately and would like to replace the cap and wires on my 1977 B.
Thanks,
Charlie
Grantura_MKI
Maybe jump on flea bay and have a look for NOS items. Later Bs did come fitted with Champion wires that where green if I remember correctly.
C
Coastalman
Thanks for the advice D! I did find a new Lucas distributor cap and a set of NGK plug wires that are exact replacement for the B on flea bay. I am waiting for a reply from a distributor of the Pertronix coil. I asked if the coil was compatible with the ballast on the late model Bs.
I'll let you know if all work well when I install them.
Charlie
C
Coastalman
I have new NGK BP6ES in my car. I have been using NGK plugs for years including using a special four prong plug in my racing 240Z back in the late 70s. I have had them in all my LBCs for years. A very good and reliable brand!
Thanks,
Charlie
YakkoWarner
So I guess my underlying question is; what is actually wrong with the parts that Moss is offering (asking mainly because that is the only place I know of to get things since Victoria British went under a couple years ago).
JPSmit
Nothing wrong with Moss. They are reputable and I have used their parts for basically my entire car ownership. Victoria British and Moss typically had the same suppliers and there have been stories on this forum of people opening a VB box and finding a Moss part number and vice versa.
That said I think that the issue is not so much Moss but that parts are typically sourced to the lowest bidder. In part because of profit motive of the company but also because most buyers tend to chose cheaper parts. I have had a couple of parts over the past years that simply weren't up to scratch. A clutch line where the tolerances on the ends were so bad I couldn't get them to seal - and something else (can't remember - possibly a solenoid) where the attached nut was metric.
Most of the parts are made of Chinesium and made in shops that literally have no idea what they are making. Amazon/ Walmart/ Dollar Stores/ harbor freight/ the list goes on where price trumps quality - and in fairness - I have many things from all of those stores where the quality is just fine.
C
Coastalman
I have used Moss Motors many many times in the past. The problem has been in parts I ordered in the last few years, maybe more than a few. In ignition parts I want the best I can get so I reached out to the BCF for ideas of alternate sources. I still buy from Moss for many other items.
Charlie
K TR2/3/3A Testing spark plug wires..... Triumph 11
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
J General Tech I Need a Set of Plug Wires! Help! Triumph 14
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
drooartz MGB Which plug wires go where... MG 5
M Restoring proper order to spark plug wires Triumph 36
wingsandwheels TR6 green plug wires, '74 Tr6 Triumph 6
JohnnyO Dist cap and plug wires Spridgets 6
Musicman Spark Plug Wires Triumph 10
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
bigjones Plug wires - anything of quality out there? Spridgets 27
T Could it be bad plug wires? MG 3
1 Spark plug wires gone 'haywire' Spridgets 16
B Plug wires Jaguar 7
H Plug wires for electronic ignition Austin Healey 18
emann plug wires for Pertronix? Spridgets 6
tosoutherncars Q - spark plug wires Spridgets 3
Got_All_4 TR2/3/3A TR3A Spark Plug Wires Any Good Ones Out There? Triumph 11
K Best spark plug wires with Pertonix:what to use? Racing 1
K "Bumblebee" spark plug wires....... Triumph 10
ronzet A Shocking experience -- Pulling plug wires MG 25
AUSMHLY Spark plug wires Austin Healey 8
danielnorton Spark plug wires Spridgets 6
Luke_Healey Generic plug wires? Spridgets 13
Woodie spark plug wires Spridgets 2
Woodie bosch spark plug wires Spridgets 5
C Spark plug wires MG 14
nathandarby67 Bumblebee Plug Wires MG 29
C Plug wires Triumph 9
drooartz Plug wires revisited Spridgets 12
T Cut/Splice Spark Plug Wires?? Triumph 13
W Replacing spark plug wires Restoration & Tools 1
Simon TR4a Spitfire Spitfire plug wires Triumph 2
T Plug wires 101 - need help MG 6
R plug wires Other Cars 3
tahoe healey spark plug wires Austin Healey 11
1 Plug Wires MG 7
D Copper core plug wires MG 3
CARSINC Spark plug thread size Spridgets 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
Carlbanan56 MGB Manifold plug MG 5
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
K TR2/3/3A Spark plug inspection Triumph 5
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
S MGB mystery wiring plug MG 2
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
