TR2/3/3A Spark plug inspection
karls59tr
Bronze
Looking at the plugs I have a nice tan colour on the electrodes, which is good, but the "threaded part" of the plugs are covered in dry black carbon? Is this something to be concerned about? Do others see the carbon on their plug threaded section or is it reasonably clean? I don't think it's running rich as the electrodes look good. I have heard that TR3s tend to load the plugs with carbon when idling but it just burns off when driving? I believe the choke is returning properly. Would I be further ahead to try a hotter plug or leave things as they are?
Geo Hahn
Your description sounds like what you want to see and what I have seen on a properly tuned engine.
I suspect modern fuel yields something other than the traditional tan color at the body of the plugs.
Sarastro
The threads don't seal. Spark plugs have either a metal sealing washer or a beveled surface that seals against the head, so the threads are actually within the combustion chamber and get the mixture forced into them on compression. They are much cooler than the plug tip, so I suspect that's why you are getting carbon there. Just a guess, however.
In any case, I can see no way that it would affect the plug's operation. You have plenty of metal-to-metal contact area on the plug threads, more than enough to get full voltage at the plug tip.
K
karls59tr
Bronze
I see what you are saying. Actually the carbon powder was just on the top ring of the threaded area ....that's probably normal seeing as how the electrode is tan coloured. (y)(y)
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
PAUL161 T-Series Odd spark plug encounter! MG 10
K TR2/3/3A Testing spark plug wires..... Triumph 11
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
M Restoring proper order to spark plug wires Triumph 36
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
K Old School Spark Plug Road Test? Triumph 6
Musicman Spark Plug Wires Triumph 10
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
T Normal/good OHM resistance through spark plug wire Triumph 17
M Carbon fouled spark plug Triumph 27
M Spark plug heat range Triumph 4
J Spark Plug life Triumph 24
W Oil leak around spark plug Triumph 6
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
K TR2/3/3A Spark plug gap TR3? Triumph 1
J TR2/3/3A Spark Plug Gap for TR3A Triumph 3
aeronca65t Spark Plug Cross Reference Restoration & Tools 3
tahoe healey Champion spark plug testor Restoration & Tools 25
PAUL161 Spark Plug Cross Reference. Restoration & Tools 1
