Normal/good OHM resistance through spark plug wire
tdskip
Hi guys - what should I expect to see by way of measured resistance on a spark plug wire? Will it vary some by length?
Thanks!
T
tdskip
Wires in question - actually from the coil to the distributor;
Reading on the longer of the two;
And the shorter of the two;
And yes, these are um, for the Alfa but I thought it might be useful to post here since I haven't seen this discussed in some time. And that seeing how red these are would make Paul happy.
CJD
Those numbers look perfect to me. The shorter wire is about 2/3 the length...and about 2/3 the resistence. If you had one twice as long, it should have twice the resistence. In my experience, a bad wire will go infinite resistence, and may come back if you twist it around while checking.
John
TR3driver
Great Pumpkin - R.I.P
Looks good to me too.
I have seen bad wires show up as high numbers, but they are really high like megohms instead of Kohms.
Whether it varies by length depends on the wire, but most suppression wires do vary by length. The center conductor is also the resistor, so longer means more resistance. But the set on my TR has a discrete resistor in the plug cap, and copper wire.
DNK
I thought not all wires are the same.
You can get info on that from the Magnecore website on theirs.
TFB
Just a thought ,but most problems I have had with high voltage ignition wires is with the insulation ,not the conductor.A megger can check insulation condition.
Tom
TR3driver
He means a megohm meter; which can measure very high resistances. It's a valid point, but I wouldn't bother buying one just to check ignition wires. You can accomplish much the same thing just by watching the engine run in the dark. If it puts on a light show, time for new wires &or cap.
Or just run your hand along the wires and see if it bites you
TFB
Hey Don,this is a common electrical testing tool that generates a high voltage to a conductor to check insulation.The old ones had a hand crank,while new ones use a small battery.
tom
Gliderman8
Glad to see you finally broke down and bought a new one don
Rhodyspit75
Mine's a little newer. I just realized the red lead is connected to the "earth" terminal. Must be positive ground. You can't see it in the picture but upside down on the meter face it says registered "Megger"
lbcs_r_fun
That instrument is useless for this test!
The purpose of a Megger is not to measure resistance, as in resistance to the flow of current. It is used to measure the insulation resistance of the wire. It is more of a qualitative test. When you crank the handle, approx. 500 volts dc is produced across the terminals. For example, you could use the Megger to check the insulation of a starter motor or even a dynamo in your TR. You would connect one of the insulated winding conductors to one terminal and the other to the case. For this level of insulation, anything less than infinity is a sign of trouble.
This instrument would be useless for evaluation of this type of high-tension spark plug wires. Perhaps it could be used to find a puncture in a solid copper ignition lead.
Regards,
T
lbcs_r_fun
DNK said:
Yo mean I gotta take mine back?
No, not at all! A megger is a very useful instrument, but not suitable for testing resistance as the original poster asked. Actually , measurement of "true" resistance of a modern spark plug lead is complicated. The value of measuring DC resistance of a sparking plug wire is dubious, because in operation the current is a complex wave shape. To define the resistance of the wire would require some very specialized instruments. The results would yield a DC component and an AC component (inductive reactance) of resistance at some assumed value of frequency.
Of course all of this electrical engineering talk has made me thirsty. I think I'll go get a coffee.
T
TFB
yes megger leads dont go from conductor end to end.One lead to conductor end ,the other to ground.I mentioned it as I know of no other test for insulation,rather than the look for sparks at night method.If the wires are in a metal conduit,say a steel loom on a flathead ford,you could ground the loom,and test loom to conductor,or to other coductors.The ones I have used go to 5k volts,so you wouldnt be able to get in the 10-20k range,but it may show breakdown on a bad wire.I have checked vintage cloth covered wires this way .You have to lay wire on metal bench or put in steel tube to test.
Temp and humididity also have an effect,and most car owners will and should just periodically replace wires.
In the vintage bike world there seems to a shift towards conservation where possible,rather than restoration,and people are using original wiring if possible.I havent seen much of this in the car world yet.
Have fun
Tom
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
B TR2/3/3A normal oil pressure in TR3 Triumph 6
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
I What is a normal engine temp for Bugeye? Spridgets 6
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
M "Normal" engine operating temperature. Spridgets 25
T How much dashpot oil leakage is normal Triumph 14
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
J Normal Engine Temp for bugeye Spridgets 1
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
