TR2/3/3A Is this normal wiring on front of steering box on TR3A?
TuffTR250
Is this normal wiring on the front of the TR3A steering box? It doesn't seem right to have the wires all twisted like that. The shielding around the wires is quite stiff and will not straighten easily. Thanks!
bobhustead
I would disconnect the wires at the bullet connectors and get the twist out. Check the individual wires for missing insulation and repair any such finds. Then I would put a large piece of heat shrink tube over the harness, push it into the tube, and shrink it on.
Bob
Kleykamp
Looks like the stator tube is turning inside the column. Have someone watch the wires and see if they move when you turn the wheels. I don't think the stator tube is supposed to stick that far beyond the nut, if any. May be a missing compression fitting behind the nut. Agree, take the wires loose at the bullet connectors and get the twist out. The stator tube should stay stationary inside the column when the wheel is turned.
CJD
Easier way is to just look at the turn signal knob at the wheel to see if it moves when the wheel turns.
The interesting thing is that normally the wire would wind and unwind when turning the wheel back and forth. I'm at a loss to figure out how it got twisted in one direction only...!?!
T
TuffTR250
Thanks! I'm glad I asked about this! A question, is the "stator tube" the brass tube coming out of the front of the steering box with the wires coming out of it? Regards,
Bob
CJD
Yes, but it's actually steel and runs from the bottom ,in your picture, all the way to the horn/signal control head at the top. The nut at the bottom should lock it, and the stator, in turn, locks the control head from turning...and twisting your wires.
TR3driver
Great Pumpkin - R.I.P
That is certainly the way it should be; and yet it looks like copper in your photo. Makes me wonder if some DPO didn't try to make his own tube from copper (they were NLA for many years).
There should be a slot at the control head end. The control head should have a slightly larger tube that fits over the stator tube and has dimples that engage the slot. The base of that slot is the most common place for them to break (weakest point and all that). If the tube is broken (or has been replaced), you should probably also look at the turn signal cancel mechanism inside the control head. I believe that binding in the mechanism is the common cause for the tube breaking.
Note that there are two different tubes, depending on whether you have the "adjustable" steering wheel or not. The adjustable version has a longer slot.
(Photo from Macy's Garage, which AFAIK is also the only source of new tubes)
CJD
Thanks Randall. The stator is broke on my new project...good to know they can be bought if its too far gone to fix!
T
TuffTR250
I checked the tube coming out the front of my steering box and it is definitely steel since a magnet held to it. I took the big nut off the front of the steering box and there is a compression fitting around the tube behind the big nut. Right now I don't have anyone around to watch the steering box while I turn the steering rod to see if the wires are twisting. I may have to set up a big mirror in front of the car. :smile:
I'm going to have to study up on how the steering wheel and turn signal pieces all fit together before I try to take anything apart. Looks like I have another project to work on that I was not expecting.
Regards,
Bob
TexasKnucklehead
I think you have something else to look at, unless the oil drained when you removed that big nut -unless you managed to not disturb the fitting. Correct me if I'm wrong, but I would expect the steering box oil to drain.
CJD
The wires cannot twist unless the control head turns. Does the control head turn with the steering wheel? It should not. You will need to retighten the nut before you check.
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
B TR2/3/3A normal oil pressure in TR3 Triumph 6
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
I What is a normal engine temp for Bugeye? Spridgets 6
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
M "Normal" engine operating temperature. Spridgets 25
T How much dashpot oil leakage is normal Triumph 14
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
J Normal Engine Temp for bugeye Spridgets 1
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
