MGB Normal oil pressure at all tempratures for 1969 MG-B
B
Bobbee44
I have a 1969 MG-B and my oil pressure at cold idle is around 30 psi and runs up to around 43-45 psi at 2500 rpm cold or hot. Is this pressure normal, or low. I am used to my Healey 3000 that runs over 60 psi cold at idle and 50 plus hot at 2500 rpm.
Thanks,
Bob
Mickey Richaud
That does sound low; should be closer to your Healey's numbers.
bob67bgt
69 has a electric oil pressure gauge. Put a real gauge on it and check the pressure. The electric units are normally slow to respond to changes.
max71
Member
I've been dealing with the same issue. According to the factory specs: Oil pressure: Approx. 60psi. Idle at 20psi. I think we're all used to 75 at speed. Someone recently said that was too high and will create leaks. I don't know.
I too have a electric sender/gauge. I've been wanting to convert to a mechanical. When I bought a cheap mechanical it actually showed my electric gauges 5-8 lbs too high. So you might want to see if the reading you are judging it on is correct. Nisonger said they have real Smith's electric senders. They claim the others are not accurate. I really do not have enough information to know if the electrical are even accurate but the certainly react slower.
Rut
True that! The sending unit is usually the culprit and the diaphragm ends up with a hole in it. I bought a new sending unit, but opted to change to a mechanical gauge for accuracy and simplicity.
Rut
max71
Member
What Rut said. There's a reason the factory went back to the mechanical gauge
I'm trying to find a mechanical one now that's calibrated. One place wants $200! :ziplip: I'm still checking :highly_amused:
In a way I feel like getting one of those dual gauges and putting it where the water temp is. But then I don't know what to put into the rectangular hole.
Rut
Try Matthews Import parts in Birmingham, AL...I bought a couple from them for $25 ea. great people to deal with and they will gave what you need.
Rut
max71
Member
Rut - they might have one. Do you know a way to calibrate these? I spoke to a speedo shop that did all my gauges years ago and they said it possible but they no longer work on them. I could hook it up to a proper gauge with a meter showing correct pressure and the check the gauge to see what it reads. If its off I'm not sure where the calibration screws etc are. Might be a nice educational post for others looking to check or do the conversion.
Rut
I just put a tee inline on the block and connected 2 gauges to it. The were both in agreement for the full range of 0-70 psi and although this is not a calibration it did what I needed it to.
Good luck, Rut
max71
Member
Rut,
There's controversy on the threads of the part that goes into the block. Is that where you put the T-line? If on the block connector some people have said its british standard thread. I had to put a new braided line in because although the other was only 7 years old the threads stripped out even with moderate pressure.
I studied about some ways to calibrate. Your way is a good way if you have a second accurate gauge.
Thanks.
Rut
I bought my gauge kit, SunPro I think, at a local auto parts store and they had the Tee as well. I asked them what I needed and took the fitting that goes in the block with me.
Rut
B TR2/3/3A normal oil pressure in TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
Thor What's a normal oil pressure Spridgets 3
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
C What is Normal Oil Pressure? MG 6
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
T How much dashpot oil leakage is normal Triumph 14
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
I What is a normal engine temp for Bugeye? Spridgets 6
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
M "Normal" engine operating temperature. Spridgets 25
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
J Normal Engine Temp for bugeye Spridgets 1
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
