Spark Plug Wires
Musicman
Hello again -
To all you TR-6 people out there, what wires are you using and why? I'm running with a stock distributor with points/condenser.
On a side note - concerning the condenser - what exactly does it do and how would you know if one was bad?
Thanks,
Dave
TR3driver
Great Pumpkin - R.I.P
The primary function of the condenser is to slow the voltage rise across the points just after they open, and thus reduce sparking at the points.
If it fails completely, the engine won't run. If it fails partially, you can usually see a buildup of metal on one side of the points.
Unfortunately they no longer make the wires I'm using on my TR3.
dklawson
On our Triumphs I am running Bosch plug wires because they were easy to get and are a "name brand". On the Mini I am running a set of Accel 8mm wires I made up from a "kit" for a Chevy V8.
I made the wires for the Mini because I am running a different dizzy and the stock wire lengths were not quite right. Making the wires from the V8 kit allowed me to make a very neatly dressed package. The Accel wires have been quite good. They have built in noise suppression but they are not strictly a carbon fiber type. I have enough "left over" material to make at least one more 4 cylinder set of wires if not two.
6969ronin6969
Not Accel or Bosch, but I did pretty much the same and got a V8 kit from NAPA, Belden, i think is the brand. And they work great. You can cut to any length you need which may add some options to routing depending on your preferences.
Eric
tdskip
David - going with a Pertronix or similar will make much more of a difference than spark plug wires. If you haven't considered it perhaps it is worth checking out. Also worth talking to Jeff at Advanced Distributors about ignition ideas. Great guy, super knowledgeable, but be aware you'll probably end up doing business with him. Grin.
Tell him Tom and about 100 other guys here sent you.
poolboy
Last time I checked Advanced Distributors was selling Bosch Premium wires.
Anyway that's what I use.
foxtrapper
The ignition is a nice LCR circuit. The condenser is the C in that. It's part of the tuning of the circuit.
When the points close, the circuit discharges to ground, collapsing the magnetic field and creating a spark at the plug. Well and good. But, the collapsing field goes right on past dead, out to the other side (boinging like a spring). In fact it will keep on bouncing back and forth for quite a few microseconds before gradually dampening down. That's not good, as you want the circuit stable before you cycle the points again for the next spark.
Enter the capaciter (condenser). It works in an electrical circuit just like a shock absorber works on a suspension, damping the suspension spring oscellations. The capaciter dampens the electrical circuits oscellations.
As a result of all this, the points will not have a spark go across them when they open. Many people mistakenly conclude that protecting the points from arcing is the reason for the capaciter, but as you can now see, that is not the case.
TR3driver
When the points are closed, a magnetic field is built up in the core of the coil. When the points open, the field collapses, and induces a sharp voltage rise in all of the windings, both primary and secondary. That means the voltage across the points tries to shoot up to several hundred volts. Not a problem if they are fully open, but they actually open pretty slowly (especially when just cranking the engine). Without the condenser, the rising voltage jumps the tiny gap at the points, and dissipates most of the energy stored in the coil, leaving none to jump the plug gap.
Oh, and the voltage still rings after the spark is over. Doesn't matter at all, because it will stop when the points close and short out any ringing still going on.
Twosheds
The official answer that the FAA wants to hear is, "Aids in the collapse of the magnetic field and helps keep the points from sparking."
I guess the magnetic field collapses quicker (to make a stronger spark) if it charges the condenser rather than jumping across the open points.
Brinkerhoff
I never really understood the condensors function until now. I've had a few fail with different symptoms: hard to start and backfiring through the carbs. They are too cheap to not replace or carry a spare.
Brosky
I use Magnecor wires on mine. I have a set that is three years old, which has never given me a problem, but I guess some of the later sets have issues, from what's been said here and on other forums.
K TR2/3/3A Testing spark plug wires..... Triumph 11
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
longbridgehealey Spark plug wires Austin Healey 8
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
M Restoring proper order to spark plug wires Triumph 36
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
1 Spark plug wires gone 'haywire' Spridgets 16
tosoutherncars Q - spark plug wires Spridgets 3
Got_All_4 TR2/3/3A TR3A Spark Plug Wires Any Good Ones Out There? Triumph 11
K Best spark plug wires with Pertonix:what to use? Racing 1
K "Bumblebee" spark plug wires....... Triumph 10
AUSMHLY Spark plug wires Austin Healey 8
danielnorton Spark plug wires Spridgets 6
Woodie spark plug wires Spridgets 2
Woodie bosch spark plug wires Spridgets 5
C Spark plug wires MG 14
T Cut/Splice Spark Plug Wires?? Triumph 13
W Replacing spark plug wires Restoration & Tools 1
tahoe healey spark plug wires Austin Healey 11
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
