BJ8 spark plug reach
Hoghead
I notice that my BJ8 spark plugs do not fit flush with the combustion chamber and are recessed about .100"
This does not seem right to me
It is a simple manner to correct this when the head work is being done, and unless I am missing something, is there a reason not to correct this apparent flaw?
H
Hoghead
Not sure if the reason for more advance in the BJ8 is a function of the recessed plug as Dimmock states or the different cam and induction system
Good point. But is the (log-type) induction system--besides being larger--much different than earlier cars?
steveg
Going out on a limb, I'd say most folks are in favor of machining the spark plug recesses down enough to bring the plug rims flush with the inside of the combustion chambers -- like the 100-6 & 100 heads. It would be interesting to cc the head before and after and use that to figure out how much it increases the compression ratio.
andrea
Hi Steve
I have on my 100/6 a late BJ8 head (long story) with recessed spark plugs
my solution is long 18mm spark plugs- I not remember exactly the code of the spark that are on my engine, but tomorrow I return with the code
Cheers
H
Hoghead
I do not think that longer plugs are the solution and one has to mill the head if the plugs are to be flush with the combustion chamber.
andrea
NGKsymbol code.jpgView attachment 26174View attachment 26175cand 1NGK BKR6E.jpg
sorry for late reply but I recuperate some photos from my mechanics
that give me this photos and indication --NGK BKR6EIX
I am not sure that it corresponding exactly at the late photos
(it is more long than 19mm )
and if anyone are interested I will control, take apart it from my engine(that runs very well with this sparks)
Note: exceeding threads, must be removed -to avoid damages
cheers
steveg
Andrea,
According to this cross-reference:
https://www.sparkplug-crossreference.com/convert/NGK_PN/BKR6EIX
the BKR6EIX plug is 19mm reach.
The longer plug on the right looks like a 26.5mm reach plug. See how it protrudes from the head.
What is the part number for the longer plug? Can you send a picture so we can read the part number.
Is the longer plug the one that runs well.
You could put another gasket under the longer one to avoid protrusion.
steveg
I was looking at these two 26.5mm Iridium plugs in the "6" heat range: NGK LFR6AIX11 and Denso IKH20 (also known as Denso 5344). These plugs are used on WRXs and other turbos and some other modern cars. I have no idea how well these expensive plugs will work.
But I like your plug better because it looks like a more "normal" plug for our cars. It also looks less expensive.
Denso has a useful chart here:
https://www.globaldenso.com/en/products/aftermarket/plug/spec/index.html
steveg
I measured the thickness of the AEC 960 head at the spark plug hole with a home-made gauge:
ThicknessGaugeAnnotated.jpg 24mm
Sighting along the bottom of the hole to the top of the piston at TDC: measuring the depth along the bottom of the hole to the point of interference with the piston: 29mm.
Thickness of crushed sparkplug washers: 1.5mm
Therefore a 26.5mm plug would only protrude about 1mm into the head - well within the 29mm.
To be extra-safe one could use two washers if desired.
To prevent interference with carbon buildup, one would want to tap out the threads before inserting 26.5mm plugs.
andrea
Hi Steve
I will take off one spark plug from my head and make one photo, inside is impossible to read anything, but sure it is NGK.
I have studied the problem more than one year ago, but never find trace of my indications to the mechanic about the long nose sparks
I remember that I give one reference and mechanic find one equivalent, easy to find on market, I see the sparks when it arrived, and remember
that was more long than normal, I am also very curious--
Same age, for me and mechanic....can be the catalyst?
Cheers
Chris_Masucci
How about one of these? I'll have to look up each part to see what the recommended gap is supposed to be, but these are all 1" reach with the right thread. Basically any of the LFR# series:
https://www.summitracing.com/parts/ngk-6499/overview/ LFR4A-E no gap listed
https://www.summitracing.com/parts/ngk-6668/overview/ LFR6A no gap listed
https://www.summitracing.com/parts/ngk-7787/media/images LFR6C-11 .043 Gap
https://www.summitracing.com/parts/ngk-6376/media/images LFR5A-11 .043 Gap
https://www.summitracing.com/parts/ngk-3672/overview/ LFR6A-11 .043 Gap
https://www.summitracing.com/parts/ngk-1116/overview/ LFR5A-11 S25 .043" Gap
https://www.summitracing.com/parts/ngk-1119/overview/ LFR6A-11 S25 .043" Gap
andrea
IMGP1996NGKLFR5B.jpgIMGP1996NGKLFR5B.jpgHi Steve
Just at the edn of the journey i take the photo of spark fro my engine
My mechanic are completely wrong spark are NGK LFR5B (more hotter)
he remember that was mounted on a Citroen C5 that is right, and on many FIAT and Mercedes-
easy to find and economic, here in Europe can be find at less than 5 EU each
Photo are very bad Sorry--but you can see that thread is partially removed at the endNGK LFR5B IMGP1995.jpg
your comments are agreed and await
Cheers
H
Hoghead
I think that having the plug protruding into the combustion chamber is a bad idea as well, and it would need to be shimmed
Since my head is off I am going to fix it properly
H
Hoghead
I have been indexing the plugs in my bikes for years, but too thick a washer will get you back to the recessed plug problem like the BJ8
These washers would work to solve the BJ8 problem, however you are going to need a pretty thick stack and it will be a bit difficult to get both proper plug indexing while being flush with the combustion chamber
Unless you have the head off you not not really know how thick a shim stack you need
If you have it off, spot face the plug hole and be done with it
If the head is on the car, then not much choice to guess on the shim stack and make the best of a shoddy situation
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
C Best Spark Plugs for BJ8 Austin Healey 14
J For Sale FREE! 2 fiberglass aftermarket hardtops, supposedly big Healey but NOT BJ8 (close though) Austin Healey Classifieds 0
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
