R & R BJ8 Transmission Bearings Procedure
AUSMHLY
What is the procedure or how do I remove and replace the transmission bearings on the 1st motion shaft and mainshaft.
I don't have a press. Thank you in advance
AUSMHLY
AUSMHLY
I found the bearing on the 1st motion shaft was a very tight fit. I needed to continually tape it gently all around to get it off.
The mainshaft bearing was easy to pull off by hand.
It's my understanding both bearing need to be pressed on or tapped on for a tight fit.
If they are pressed on, should I be concerned that the mainshaft bearing slid off by hand?
The mainshaft bearing has a tight fit in the bearing housing. The housing doesn't have a tight fit in the transmission and I can spin it by hand to line up the pin with the pin hole in the OD. That will keep the housing from rotating in the transmission case. How tight should the bearing housing be in the transmission?
I'm trying to locate the area(s) that's causing problems with loud gears, gears chipping and finding metal filings.
I'm thinking there's too much slop or float with the 1st input shaft or mainshaft or both. That may cause too much play between between the two shafts. There is a new cage roller bearing there. I have also installed a new bush spigot in the engine. The laygear has .012 end float.
Should I be concerned that the mainshaft bearing slid off by hand?
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
WHT BJ8 Transmission Installation Austin Healey 0
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
G BJ8 Transmission Front Seal Austin Healey 10
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
4tecdog BJ8 Transmission housing smoke Austin Healey 14
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
E BJ8 Transmission Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
