BJ8 Transmission Oil Capacity
AUSMHLY
I've always put 3.5 qts of 30w ND oil in my BJ8 transmission, which I believe is the correct amount.
I've had problems with 2nd gear, and decided to rebuild the transmission. Once opened, I found the Laygear's 2nd gear had pitting on every tooth. 2nd gear didn't have any coating on hub. Time for a rebuild.
I'm learning how to rebuild this and found I needed to replaced almost every part. Selector shafts were bent, forks were worn as were all the baulk rings. Replacing the 1/2 hub fixed getting into 2nd. Replaced 3/4 hub, easy smooth shifting now. New AHS remanufactured one piece Laygear plus new layshaft and cage bearings.
On the bench it shifts fine.
During the rebuild the tranny is dry. I didn't take the OD apart. I have it face down in a pan for weeks and no oil drips out anymore.
Once the trany is in the car, it only takes 3 qts for the dipstick to show full.
Cars on jacks, start the car, smooth shifting, 2,3,4 gears sound about right. After 1 minute of shifting, I check the dipstick, the oil is light green, which I assume is air. Why is that? OD works fine, with 500psi. An hour later I'll take the car around the block. Under load shifting is easy, smooth, however 2,3,4 gears are loud, 2nd is loudest and even louder on deceleration. The next day I'll check the level, no air, it shows full. Drive around the block, gears are loud.
In order to install the new AHS laygear, I needed to sand the front thrust washer to .0645, the rear sanded to .0740. This was to get the gears on the mainshaft to line up with the gears on the laygear. End result was 0.012 endfloat.
I now doing a trial fit with a rebuilt laygear with the welded 1st gear. It also needs front .0645, rear .0740. The thinest front thrust washer from AHS is .0790, the thinest rear is .0800. It seems strange that I have to sand the thrust washer to get both laygears in. The original laygear that I took out, I don't know what sizes the trust washer were. When I try it now, the thrust washer are thicker, so it seems Laygears are not uniform.
Are the gears loud because of 3 qts vs 3 1/2?
Are the gears loud because of the laygear?
Why is 2nd gear loudest especially when deceleration?
I though the gears may be loud because there's only 3 quarts, but the dipstick show full. Dipstick wasn't changed.
Because the OD works, I'll assume there's enough oil in both he tranny and OD.
I'm at a loss of only 3 qts. I added 1/2 quart, drove it around the block, gears are still loud, dipstick showed past full. I removed enough oil to bring it to full, which was 1/2 qt.
I've removed this transmission 7 times now replacing parts and every time it only takes 3 qts. Every time, I had the OD sitting in a pan till no oil drips out. I feel like I'm in a twilight zone episode.
Thoughts? (not about being in the twilight zone, lol)
John Turney
You have 1/2 qt. of oil remaining in the OD that doesn't drip out. If you were to disassemble the OD (DON'T DO IT!), you would find that extra 1/2 qt.
Do you have the tunnel on when doing test drives?
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
WHT BJ8 Transmission Installation Austin Healey 0
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
G BJ8 Transmission Front Seal Austin Healey 10
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
4tecdog BJ8 Transmission housing smoke Austin Healey 14
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
E BJ8 Transmission Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
