BJ8 transmission mainshaft bearing force needed to install/remove
AUSMHLY
I'm rebuilding the BJ8 transmission.
I used a hammer to get the dry bearing into the dry mainshaft bearing housing/carrier. (I don't have a press). Very tight. Putting the dry bearing/housing on the dry mainshaft, it takes just a couple light tapes with a hammer. Yesterday I was able to pull the bearing off with my hands, no hammer tapping to get it off. (Everything is covered in 30w non detergent).
A Youtube video by Manus Karlsson, “Austin Healey Mainshaft Assembly” at timing mark 4.00 shows him hamming the bearing on the shaft.
My gearbox is loud and I'm finding metal filing on the magnet I installed. Could the issue be related to the bearing not being as tight on the shaft as the video shows?
If I put a new bearing on and it doesn’t take much force to put it on, is there anything I can do to the shaft where the bearing sits, to have it tight? Or do I need to buy a good used mainshaft or new mainshaft?
As always, thanks for your help.
Platinum
Not to be a 'Debbie Downer' here, but it would be my advise that the mainshaft be taken to a (competent) machinist who could build up the diameter of the shaft (not just torch some material on it, rather "spray" it as crankshafts are built up) and turn it down to spec. A slight interference fit, no idea what the original diameter should be, but somebody here with a good shaft should be able to use micrometers and post it.
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
WHT BJ8 Transmission Installation Austin Healey 0
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
G BJ8 Transmission Front Seal Austin Healey 10
JamesD For Sale BJ8 engine & transmission parts Austin Healey Classifieds 3
4tecdog BJ8 Transmission housing smoke Austin Healey 14
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
E BJ8 Transmission Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
