BJ8 Rear Backrest Hinges
Healey Nut
I think I have a used set
Healey Nut
So I went and had a look in my shop . I have almost a full spare set . One of the offset hinges is missing . I remember buying a new set when I did my 67 I think one must have been broken . The brown goo on them is glue no rust .
I have all the screws as well .
PM me if you’re interested .
B
bigarestorations
Thanks!
I, as you do, only have one offset hinge bad.. I'd love to have one if you'd sell me one instead of the whole set.
My other hinges are fine and I'll be refurbishing all of them in powder coated chrome so they all match and look new! Let me know if you want to let one offset go and how much.
Thanks so much!
Bennet
Healey Nut
Thanks!
Thanks so much!
Bennet
Send you a PM conversation
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
S BJ8 Rear Seat Side Panels Austin Healey 3
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
AUSMHLY Squeak from rear of BJ8 Austin Healey 51
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
RickPA BJ8 rear wheel cylinder install Austin Healey 1
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
J BJ8 early P2 rear spring mystery - what do I have. Austin Healey 6
B BJ8 Rear Brake Questions/Advice Austin Healey 4
J Rear axle noises==BJ8 Austin Healey 7
B Rear view mirror location for BJ8 Austin Healey 14
Jeepster BJ8 rear leaf springs Austin Healey 2
L BJ8 Rear Interior panel fitting Austin Healey 7
C BJ8 Rear Seat Back Carpeting? Austin Healey 3
L 1966 BJ8 rear trim panels Austin Healey 8
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M looking for rear end gears for bj8 Austin Healey 25
A BJ8 Rear Drum removal Austin Healey 8
Jeepster BJ8 rear seats Austin Healey 12
AUSMHLY BJ8 Rear Trim Rail Austin Healey 34
S BJ8 rear brake drums Austin Healey 8
B BJ7 & BJ8 soft top rear seal Austin Healey 2
L BJ8 dome nuts on rear interior panel Austin Healey 5
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
B AH BJ8 REAR SPRING INSTALLATION Austin Healey 5
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
S BJ8 Rear Seats Austin Healey 7
J BJ8 rear boot floor replacement. Austin Healey 9
S Rear springs - BJ8 Austin Healey 1
AUSMHLY BJ8 rear wheel well gap size Austin Healey 17
A BJ8 Rear Seat slide bolts Austin Healey 1
A Tinkling rear brakes [BJ8] Austin Healey 5
H Rear springs BJ8 Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
