BN4 to Early BJ8 Rear Axle
John Turney
I've been having trouble keeping left rear wheel bearings in my BN4. This morning, I measured and the left end of the axle case is bent. Anyone have a spare they are willing to sell?
I have another diff that I could strip out from BJ8 and then theres another one from a 100/6 I could strip. Still frieght is going to be expensive
John Turney
John Turney
John - have you talked to any axle places? they might be able to straighten it or cut the end and re-weld it. Gotta believe this sort of thing happens with trucks or farm equipment.
The closest place that I could find was in SoCal. Nothing in this half of the state.
This is a long shot, but my landscaper recommended these guys for hydraulic cylinder and other tractor/farm equipment repair (NFI):
ESSCO Tractor Repair
209.545.0751/209.545.2775
1024 Thieman Rd.
Modesto, CA 95356
CraigC
John, assuming you have repaired your car, what was the solution? Did you find someone to straighten the housing or did you replace it?
Healey Nut
If the axle case is bent then wouldnt you also get strange tire wear ?
Michael Oritt
John--
I have had axle tips successfully welded onto the end of the A-series (spridget) axles on two of my race cars. You do nor need to find an axle shop, merely a person with good welding skills who can accurately set up the tip.
H 3 ltr engine BN4 to early BJ8 - dipstick markings Austin Healey 8
B Side window question for early Longbridge BN4 Austin Healey 4
Csarneson Early BN4 steering box pitting Austin Healey 16
K Correct side screen nut for early 58 BN4 Austin Healey 14
L Need a early BN4 hood bow Austin Healey 1
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
R Early BN4 Seat Covers Austin Healey 10
Csarneson Early bn4 dipstick tube removal Austin Healey 7
B Source for Brake Tank Assembly for early BN4?? Austin Healey 4
V Early BN4 top vs. Later BN4 top,... Austin Healey 2
V early BN4 question - top & header rail Austin Healey 3
andrea EARLY BN4 STEERING BOX washers belleville Austin Healey 6
H Early Longbridge BN4 Tool Bag Austin Healey 3
andrea WIRING DIAGRAM for imprved BN4 100/6 and early BN7 Austin Healey 3
5 Headers for BN4/early 3000 Austin Healey 10
M BN4 [early] Toneau bar Austin Healey 4
ronzet Looking for pictures... Early BN4 interior Austin Healey 13
M Early BN4 tach cable routing Austin Healey 0
A 100/6 BN4 Restoration Austin Healey 7
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson BN4 Cam Gear Install Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
