BN4 Cam Gear Install
Csarneson
This is an embarrassing question to ask. Be gentle...
I've been sidetracked doing body beating and I'm finally finishing up the rebuild of my BN4 engine and am putting the new gear on my reground cam. The bottom of the engine is already closed up. I suddenly realized that the cam is able to slide quite far into the block and getting the gear on far enough on to the end of the cam to get to the threads isn't easy. Did I miss something on the far (back end) end of the cam which keeps it from sliding in? I can't see anything in the manual. What holds the cam in position other than the single retaining plate and then the cam gear? I was expecting to tap the gear onto the cam but I can't because the cam slides in too far. I fear I missed something important inside.
red57
Don't panic, you didn't forget anything. The thrust plate behind the gear is the only thing that locates the cam - the front shoulder of the front bearing race stops forward movement against the thrust plate and the rear side of the cam gear stops rearward movement against the same thrust plate.
If you don't have the engine rear plate on then you can reach in and stop the rearward movement of the cam with your hand from the rear of the motor. If the rear end plate is on, I'm not sure where it will be best to hold the cam while the gear is pushed on enough the catch some threads with the cam nut - possibly a large screwdriver in a lifter hole? (careful not to scratch a lobe). If you can get the gear on enough to catch threads you will be good (try it without the lock-tab washer to get it at least part way on, then remove nut & install the lock washer). The gear is normally a very light hand press fit on the cam so hopefully won't be too hard to get on enough to get the nut started.
When you do get the gear on don't forget to check the cam end float - should be 0.003 to 0.006. Can't check until the gear is tight on the shaft.
Dave
Csarneson
Csarneson
Thank you so much! While I am a pretty handy guy, this is my first attempt at rebuilding an engine. I'd been so careful at each step and it was completely demoralizing when I suddenly thought I had missed something major.
DO BE CAREFUL about letting the cam drift in too far, as the #6 exhaust lobe will damage the rearmost bearing.
BTDT
I'd at least temporarily bolt the rear plate on before going any further with the cam gear installation (or maybe just a bar bolted to a couple of strategic holes, so long as it stops the cam).
A 100/6 BN4 Restoration Austin Healey 7
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
L Need a early BN4 hood bow Austin Healey 1
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
