Wanted Servo for BN4 has to be original 1957 or before any condition considered.
Wrovert
I am renovating a Austin Healey 100/6 Bn4 I would like to fit a break servo bit it has to be original 1957 or before. The car is being prepared so that I can enter the Italian 1000 Miele race so every thing has to be original or as could have been fitted up until 1957. I would be happy to refurbish ,or one already refurbished, a unit and will consider any condition.
BoyRacer
BN4s did not have brake servos.
W
Wrovert
Yes I know but for 1000- Mile race you can have upgrades as long as they are age related. so the
keep the original front brake drums I was hoping to uprate the efficiency of the braking system. May be just to ambitious so I will stay with original setup.
Thanks for your reply though it was helpful.
BoyRacer
An age related upgrade would be disc brakes.
Jerry
I converted my 100 6 to disk brakes, it was a great improvement in braking power. I think it was an option available for the cars so would be period correct.
BoyRacer
100S's had disc brakes. It is period correct.
W
Wrovert
thanks for your help and you are all right disc brakes on the front was an age related upgrade for the 1957 BN4
BoyRacer
Early 3000 disc brakes (Girling) are a direct bolt on to a BN4. I believe the 100S disc brakes were Dunlop. And those are unobtainium.
W
Wrovert
I might have found my own answered to this? The BN1 seal is 2.3/4 inches for all other cars it states on the suppliers sites BN4 To BJ7 2,7/8 inch I measured mine and it is actually 2.3/4 inch so even though it a a BN4 car it still uses a BN1 Oil seal.
I know that the can was and early BN4 Longbridge built car, so may be this is the reason ?
Speedsports
Four-wheel disc brakes were an option on the BN4. I believe they were the same as on the 100S.
100-Six optional Dunlop disc brakes were not the same as the 100S. A quick way to recognise the difference is the 100-Six has a two bolt fixing on the calliper where a 100S has four.
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M Brake Servo Austin Healey 2
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
Walter74 Brake Servo Location Austin Healey 6
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R Brake Servo Rebuilder Austin Healey 14
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
B Vacuum Servo Austin Healey 19
H BJ8 Exhaust System and Brake Servo Austin Healey 16
C TR6 Brake servo leaking Triumph 3
B Power Brake Servo for a 100 Austin Healey 3
M Orientation of Lockheed brake servo Austin Healey 2
R Healey Marque Brake Servo story Austin Healey 6
N Spitfire brake servo in a spitfire Triumph 3
D Removing servo . Good or Bad Austin Healey 12
H BJ8 Servo Austin Healey 8
S Brake Servo Installation Austin Healey 13
D TR6 Brake servo and rear tire rubbing Triumph 4
C Servo fitting MK1 3000 Austin Healey 1
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
R BJ8 with servo...Brake travel issue Austin Healey 30
R Installing an aftermarket brake servo kit Austin Healey 6
S brake servo Austin Healey 3
L BJ8 Brake servo Austin Healey 6
D TR6 76 TR6 Brake Servo Triumph 2
W brake servo install? Triumph 1
W brake servo Triumph 3
W Brake fluid in Servo/booster Triumph 5
D Brake servo Austin Healey 1
Frank C. Brake Servo Replacement Austin Healey 6
M Remote Vacuum Servo Spridgets 14
T 77 with twon SU's- need to remove brake servo MG 2
Jeepster Servo Austin Healey 15
tahoe healey servo forgotten maintance Austin Healey 9
richberman any pictures of servo Austin Healey 5
John_Mc Brake/Servo issues Triumph 7
T XKE Series 2 Brake Servo Jaguar 2
B Brake Servo Parts... Triumph 1
B brake servo plumbing for BJ7 Austin Healey 8
J hints on rebuilding brake servo? Triumph 9
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
H TR6 Tr6 Servo Diaphragm Triumph 2
D brake servo Austin Healey 6
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
J Is my brake servo working? Austin Healey 5
chicken Brake servo pipe routing Austin Healey 1
RomanH Brake Servo Triumph 2
N Brake servo air filter Austin Healey 2
