Frank C.
My servo started to "hiss" when I put on the brakes and the result was no assist and poor braking. Thinking I had an original Girling unit I ordered the Moss repair kit but noticed that when I removed the servo, it was slightly different than the units shown. The main difference seems to be in the vacuum chamber, they show the cover removable with screws but mine is crimped all around and doesn't look like it is easily repairable. That seems to leaves me no option but replacing the entire unit. Ok, Moss shows two options here, (981-173) listed as a Lockheed replacement for $389.95 and (981-174) listed as an aftermarket replacement for $239.95. Both seem to need a $124.95 bracket set to install.
My question: Given the large difference in price, which unit should I go with? Or, is there another option.
Thanks for any help you guys can provide.
