Power Brake Servo for a 100
BLU_HLY
Member
What location on a BN2 can a servo be installed? The outside of the passenger side footwell would be ideal, however there is a bracket to hold the brake/clutch shaft and a bracket for the master cylinder intended for a right hand drive. With these brackets in place there is no room for the servo. Where else ?it be ;ocated
DerekJ
To be honest I don't believe a servo is necessary on a 100. If it still has its drum brakes they are leading shoe type so effectively have a servo effect built into them.
steveg
I have an acquaintance who has a power servo on his all-drum BN6. IMO it results in too-sensitive braking.
busybrit
I agree with DerekJ, you shouldn't need a servo on a 100. If the brakes are set up/adjusted correctly, they work fine. To get them better without a servo I installed Kevlar lined shoes on the front. Once bedded in they really work well.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
hondo402000 TR6 TR6 power brake bleeder Triumph 10
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
R Painting the Power Brake Booster Triumph 11
1965_MGB Power Brake Bleeder Anyone? Restoration & Tools 7
T GT6 1973 GT6 Power Brake Booster Triumph 4
B Info needed: E-Type power brake tool J 31 Jaguar 0
B Tips on rebuilding E-Type power brake master/slave Jaguar 4
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
R BJ7 wiring power path Austin Healey 21
