TR4/4A Out of the blue - started to loose power
Eeffoc
Hey everyone, I am in need of your help
Up until recently the car has been running not bad, accelerates through all the gears just fine, then gradually at highway speeds I started loosing power.
Now the symptoms of power loss has gotten much worse, I can accelerate through 1st and 2nd (shifting around 3500 rpm) but when I get to 3rd and around 3000 rpm I can do no faster and the rpm's go no higher and it sounds like I am running on 3 cylinders or starving for fuel.
  • The car starts fine with a little choke when cold and will idle fine with no choke shortly there after
  • There is an occasional pop when listening to the exhaust - like it is missing
  • I've been using the highest octane fuel I can get
  • Carbs are ZS
  • Mechanical Fuel pump
  • Electronic ignition
So far I have done/checked the following:
  • Set the static timing
  • Checked the plug wires - they all measure between 2.8-3.2 K ohm and are practically brand new
  • Checked the cap and rotor - they look practically brand new
  • Checked the fuel pump bowl (it's clean)
  • Checked the inline fuel filter and it is clear
  • Checked the fuel pressure with the priming lever into a pan
  • Thought it may be vapour lock but this is happening at the start driving before things get really hot
  • Checked the coolant
  • Checked the oil
  • Checked the carbs to see if they are balanced (they are pretty close)
  • Checked the dashpot oil
  • Checked the pistons to see if they move freely and drop quickly and they do
  • Checked the mixture by lifting the piston - not sure if I got this fully figured out but the RPM doesn't drop right away (maybe after 3-4 sec)
I haven't pulled the plugs out yet but I had replaced them a year ago
After looking at the plugs I'll have run out of ideas on what to check next
I need help
Thanks
Gliderman8
Maybe replace the coil if you have one laying around.
KVH
I'd try replacing the coil. Curious, is anyone telling you you're blowing a cloud of smoke when shifting from 1st to 2nd, or 2nd to 3rd? Are you sure there's no sticking of those carb pistons? I don't have Z Strombergs, but after first thinking mine weren't sticking, I saw they were at the very upper end of the travel range. Zero problems ever since I fixed that problem. Did your problem follow any recent engine work?
NutmegCT
What exactly indicates you are losing power? The engine starts firing erratically ("missing") at high rpm under load? The engine starts firing erratically ("missing") at high rpm *not* under load? The engine is slow to accelerate at high speeds? The car acts like brakes are too tight and get even tighter at high speed?
If the engine is "missing" only at high rpm, whether or not under load, I join the "replace the coil" camp.
Tom M.
bobhustead
Get rid of the electronic ignition. Install new cap, rotor, points, plugs, coil, and condenser. We can go from there if it isn't then fixed.
Bob
Eeffoc
Eeffoc
I'll double check the carbs, I'll be pulling the pistons out and cleaning them but they were moving very freely. No recent engine work and just today I had a friend follow me for a bit and he had mentioned that there was a hint of blue smoke. Looking into a new coil as well now
Thanks for the assistance
Eeffoc
Eeffoc
Tom M.
The car acts like it is bogging down, it starts out fine and accelerates like normal then things get sluggish... I'm not explaining myself very well, I'll see if I can post a video of what is going on
Eeffoc
Eeffoc
Bob
I'll look at getting these parts ordered and give it a go and see what happens.
Thanks
Eeffoc
Eeffoc
Sounds like the timing is not advancing as you pick up RPM.
steve
I thought that as well but after I set the static timing I put a timing gun on it and increased the rpm's and the timing mark would advance. I suppose it could stop working while driving though.
KVH
Can you verify that blue smoke? Is it a hard puff when shifting at about 4000 RPMs? Separate thought—has that electronic ignition historically worked well at high speeds and rpms? About those carb pistons, the give-away for me was that they were sticking at the upper limit. Finally, you mentioned missing. Do you have missing every single time you reach higher RPMs, or is it something only occasional?
CJD
Is the tank vent clear?
From what I am understanding, the engine does well in 1st and 2nd, but then bogs in 3rd and 4th? If so, I would concentrate on fuel delivery. Ignition would bog at higher RPM in all gears. The engine uses more fuel as the gears go up, making fuel delivery the likely cause.
mctriumph
Hamish is spot on. If you do NOT use fuel injection lines back at the tank, they can swell shut and strangle the flow.
also at the pump ONLY fuel injection grade hose. The quality of fuel line has plummeted in the last 10 years.
MAD DOG
sp53
Sounds like fuel deliver to me now. I once had an electric fuel pump with a regulator and it did the same thing when turned down too low.
steve
Eeffoc
Eeffoc
I've ordered some parts, while waiting for them to arrive I'll try out the other suggestions.
I'll update my progress as things change.
Thanks everyone
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
PAUL161 T-Series Puff of blue smoke on startup MG 17
S Baby Blue gets a Shout Out from BaT Spridgets 4
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
BoyRacer Rattle can Healey Blue paint Austin Healey 2
BoyRacer Blue Vinyl Dash Material Austin Healey 3
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
J Opalescent Silver Blue paint code Jaguar 0
B TR4/4A Midnight blue interior Triumph 6
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
R TR6 Sapphire Blue color Match? Restoration & Tools 3
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Mickey Richaud TR2/3/3A From Out of the Blue! Triumph 12
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M TR2/3/3A Red or Blue Loctite Triumph 1
HealeyRick Healey Blue Austin Healey 12
glemon Iris Blue Spridgets 11
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
L Ice Blue [BU2] touch up pen Austin Healey 5
Mickey Richaud Blue Healey on the Blue Ridge Parkway Spotted 0
K Healey Blue Paint Source Austin Healey 30
wangdango BJ8 gauge blue jumper? Austin Healey 2
A Iris Blue vs Speedwell Blue Spridgets 10
Scotsman TR4/4A Triumph Royal Blue paint code and formula Triumph 3
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
NutmegCT blue/gray exhaust smoke Other Cars 13
S Baby Blue to the Rescue...again Spridgets 8
DerekJ Healey Blue Paint - suggestions Austin Healey 23
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
Keith_M Now the smoke is blue/gray Spridgets 10
S A Playmate for Baby Blue? Spridgets 19
bighealeysource My Healey at a Blue Angels Air Show in Beaufort,SC Austin Healey 0
J Pacific Blue paint code needed Jaguar 6
HealeyRick Blue Bristleflex? Austin Healey 3
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
S Happy Birthday, Baby Blue! Spridgets 6
Rut Iris Blue interiors Spridgets 15
simon1966 Armacord in the trunk, Healey Blue BN1 Austin Healey 5
S Were Valve Covers Ever Painted Blue? Austin Healey 8
weewillie baby blue Spotted 1
KVH TR4/4A Baby Blue TR4 Triumph 2
RichBall OT Once in a Blue Moon Spridgets 3
longbridgehealey blue bugeye on a trailer Spotted 2
J Rivera Blue with Tan interior? Spridgets 2
M Today on the Blue Ridge Mountains Triumph 34
B Iris blue BE for sale Spridgets 0
