Engine Swapping for Straight 6 Power
billspohn
Quite possibly not many engine swappers here, but I own both classic and modern sports cars and sometimes the possibilities of re-engining an old sports car with a modern engine come to mind. I have done this in my Jamaican bodied MGA, using a 3.4 GM 60 deg. V6, as have many others into cars like TRs and MGBs.
My candidate is a straight 6, but like nothing I can recall in past practice. I own a BMW Z4MC, and the DOHC 3.2 I6 they come with has 11.5 compression, and puts out 338 bhp at 7900 rpm (and with a stroke about the same as an MGB).
As with any modern engine swap you need to either use the existing engine management system from the modern car (highly recommended) or come up with an after market solution (often harder and more expensive).
This engine comes with a 6 speed manual gearbox and the engine weighs in at around 470 lb (they run a cast iron block for rigidity and an alloy head). They should fit fairly easily into a Healey with a 6, a Triumph TR6, an MGC, and a few others (obviously Jaguars) as well as other marques (which is why I posted in this section).
They don't look like an old style DOHC six because they have a cover that encompasses both cams. They run six individual throttle bodies and a rather nice looking stock tubular exhaust. And they sound better than any V8 and many straight 6s with a real banshee wail at high rpm.
Thought I'd just throw the idea out there for anyone that wanted to double the power of their vintage Jaguar or Healey (and if you want to rush to tell me that an XKE had 265 bhp, when they in fact had about 190 hp net/modern measure, don't bother).
JPSmit
Interesting Bill, what are you centemplating putting it in and how does it compare size wise?
JPSmit
billspohn
billspohn
I'd love to see it in a Jag XKE - double the power and way less weight.
But then I'm an iconoclast - I'd love to show up at a Corvette show with a C2 Vette with a 4 cylinder LNF motor in it putting out 450-500 bhp. Bet they'd love a little 4 cylinder that exceeded the output of the V8s they came with (my street Solstice coupe has an LNF that produces 375 bhp and 375 Tq, and gets 30 mpg when your foot isn't planted - very good good mileage when not under boost!
Of course the Corvette guys would likely lynch me.....
As would some of the MG crew for doing this!
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
D Swapping 948 for 1275 engine Spridgets 11
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
