For Sale Hoist and engine stand
JAJohn
Member
Bronze
I have for sale a hydraulic engine hoist shop crane and an engine stand. I have finished the mechanical work on my TR3 and have no use for these any more. The hoist was used maybe a dozen times, and the engine stand held my replacement block for about a year while I swapped parts from my old broken engine.
The hoist is rated 1.5 ton, and is supposedly foldable, although I never folded it.
Asking $125 for the hoist, $50 for the engine stand, or $140 for both. Negotiable.
Contact jajohn1469@gmail.com
D engine hoist Austin Healey 11
R engine removal- where to connect hoist? Austin Healey 16
T engine hoist Austin Healey 14
B TR2/3/3A Pulling engine & trans on TR3B - hoist attach? Triumph 6
Morris Engine hoist... Spridgets 25
1 MGB-GT Engine hoist/crane boom length? MG 17
S Engine Hoist Restoration & Tools 13
Mickey Richaud Engine Hoist Restoration & Tools 17
drooartz Engine hoist--buy or rent Restoration & Tools 11
vping Engine Hoist Bracket Spridgets 3
beez Lifting body with engine hoist Triumph 4
Basil Engine hoist info Restoration & Tools 5
J TR6 TR6 Hardtop Hoist Triumph 2
J Wanted TR6 Hardtop Hoist Triumph Classifieds 1
stretchit2 New Lift/Hoist for my Hardtop Austin Healey 11
DART Hardtop Storage hoist Restoration & Tools 2
jackq overhead hoist/trolley Restoration & Tools 16
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
