A-series Engine Block Search
sim
I am looking for an A-series engine block that has 3 cam bearings.
The block I have has only one installed cam bearing the other 2 are just the cast iron block.
I live in California. The engine is a 948.
pan
G'day Rod,
Your enquiry might get more response from the Sprite owners on their dedicated forum. You may have a Morris Minor engine. I believe the A-Series engine used in the Austin-Healey Sprite differed from the Morris Minor unit in having the extra camshaft bearings. On the Minor (and possibly also the Austin A30) the camshaft runs in the block.
Cheers,
Alwyn
Bristol401
Member
Throw the 948 block away and get a 1275. From what I’ve seen, upgrading to a 1275 does not lower the value of a classic Spidget. I have a few of these, also a 970cc race motor.
A Making an A-series engine stand adaptor fitting Spridgets 2
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
Boink Cut-away B series engine... MG 6
theleisure Inside an A-Series Engine Spridgets 6
78Z B-series Engine ID MG 24
aeronca65t A-Series Austin engine Other British Cars 0
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Creatrixx A+ head on an A series engine? British Motor Corp 8
mjamgb Modern pistons for a 3-main B-series engine Racing 15
Sherlock BMW 3-Series [with Corvette engine!] Other Cars 5
coldplugs A series OHC engine British Motor Corp 5
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
